Try as I might I have been unable, so far, to find a review of this amp but I did find a review of the Carver receiver and here is the link:
https://worldradiohistory.com/Archi...iFI-Stereo/80s/HiFi-Stereo-Review-1984-04.pdf
It's on page 22. They were getting distortion under .005 up to 100 wpc.
Unfortunately the scanned review of this receiver from Audio Magazine had the pages cut out...
Thanks for the link. I love the talk of "The Digital Revolution".
From the review:
The distortion ratings of the Carver receiver's amplifier section proved to be quite conservative. With both channels
driving 8 -ohm loads, the distortion was
less than 0.005 per cent from 1 to more
than 100 watts output, reaching only 0.01
per cent at 150 watts. With 4 -ohm loads,
the distortion was 0.007 to 0.01 per cent between 1 and 90 watts, rising to about 0.03 per cent in the 150- to 200 -watt range. With 2 -ohm loads, the distortion
was 0.01 to 0.02 per cent up to 30 watts,
reaching 0.1 per cent in the 200- to 250 -
watt range and 1.74 per cent at 300 watts. Because of the rapid internal heating,
high -power measurements at 2 ohms had
to be made quickly, with only one channel driven. Nevertheless, the receiver suffered no ill effects from the abuse it received during our tests. Measured at the rated 130 watts or
less into 8 -ohm loads, distortion was between 0.003 and 0.01 per cent from 20 to
4,000 Hz, increasing to about 0.025 per
cent at 20,000 Hz. The amplifier section
was stable with complex reactive simulated -loudspeaker loads, but it showed
the typical overshoot and ringing on
high -frequency square -wave signals. I
