JP, that is just.........just.... OVERKILL! Exactly what I would do too if I was into vinyl. Nothing like overkill to make you feel proud and happy. Fantastic pic.
Matt, I align tonearms routinely for clients, grandsons, and of course myself - it gets easier with practice. I include the usual tracking force, the visual method from my Phonograph book for skating compensation and the free tools in it for optimizing resonance - often ignored because it's misunderstood. And don't forget capacitive loading of MM\MI cartridges at the preamp input, also often ignored and highly detrimental to tone color.
Ok. You have a point.
Does a reduced VTF increase wear on the groove?Then if I want, for instance, a bit more lush sound I can increase the VTF or go the other way for a slightly more leaner/brighter sound. (I prefer more lush).
My biggest issue mounting cartridges is that my 'table isn't in a spot with easy access and it's at an odd height. I use a Mint LP protractor. It's a lot easier if you're good at knowing which way to move things to get them to align, and know tricks to keep the cart from moving around before and while you're tightening things down. Being good with small motor help a lot.
I think the biggest improvement I had was getting better magnification. I use a 4x objective from a Mantis Elite inspection scope. Far less fiddly to get a good view with that than the usual options.
I can do a cartridge in about ten minutes.
You must have missed the Courteous Vinyl Playback Discussion thread. Specifically created for people who want to discuss vinyl without the aggressive negativity (which tbh is underpinned by a strong desire not to allow the 2x4 Biff Tanner digiphobes to get a foothold and ruin this forum with their special hifi religion that has poisoned so many other forums for so many hobbyists for so long).On the other hand, I've pretty much written-off ASR as the home for analog technical discussions, which is a shame as a good number of the technical members here do have a lot they could share. The Biff Tanner welcoming duo pretty much makes it a non-starter, which seems to be their intended purpose. Call me funny, but I just don't think a 2x4 to the forehead of 'vinyl is bad and you're an idiot for listening to it' is all that welcoming, regardless of how open-minded a person may ultimately be.
No, wait, you didn't miss it. I see lots of posts by you there. Problem?
Ok cool, another mint user!
A big problem for me is the design of my Benz Micro Ebony L cartridge, it's a very low-slung design so, once the needle is set on to the mint tractor, it's REALLY hard to get a view of the stylus. I nave not found any easy way around this. I have tried all sorts of different magnification devices, loops of various strengths, jewelers glasses, and I have a good USB microscope. None of them allow an easy view of the needle for adjusting because no matter where each is placed to try to get a view, the cartridge head or mint protractor edge gets in the way. Eventually I get there though.
I tried the USB scope thing and found it fiddly AF. Not for me.
The Mantis objective has a 96mm WD, 34mm FoV, and guesstimating aFoVDoF of about 10-15mm. It's VERY forgiving and actually difficult to not see what you need to see. Expensive though, but used examples can be found for a bit less than $100. I wasn't able to find my peak loupe one day and grabbed the Mantis. Revelation.
That's the one. Likely there are other optics with similar specs for less. These are really nice quality - overkill for this use.Do you mean something like one of these?
Vision Engineering MEO-004 - Objective Lens for Mantis Elite Series Stereo Microscope - 4X Magnification
Buy Vision Engineering MEO-004, Objective Lens for Mantis Elite Series Stereo Microscope, 4X Magnification, Visual Inspection System Accessories, Visual Inspection Systems & Microscopes, Inspection & Testing, MEO004, V016-000020, V016000020 and related products.www.qsource.com
Ok thanks. So if I understand it, those are easier to use because they have a wider opening giving a wider angle of view, vs squinting through the narrow view of a
loop?
The issue I see for me is: how do you sit the Mantis so it stays steady? I have to use two hands when adjusting the cartridge. The loops will sit steadily on my turntable platform freeing my hands (though, as I said, not with a great angle for viewing).
Please share.... this is the part I struggle the most with.
