I bought a C-note kit as soon as it was aval. and was not impressed w/ the results and they sat around for a couple of years unused.
Eventualy, I decided to try and do something w/ them, so I installed the cross-over and tweeter that Matt Grant designed for his NEXUS series of speakers;
Timbre matched family of Hi-Fi/HT speakers all based on the same midwoofer (Dayton DS135-8) and tweeter (ND28F-8). These designs came about from my...
www.hificircuit.com
To install the larger tweeter, I lopped the ND25 tweeter off the wave guide and siliconed the ND28F-6 in it's place. It fits exactly the same and one would be hard-pressed to see any difference once installed.
Matt's X-over is complex w/ a high componet count and he had to go back and revise it;
Matt wrote, "The TM had an unexpected peak near 900hz and....... I ended up doing (another) full set of measurement(s) with a crossover fix for that peak."
The extent that Matt went to w/ the X-over probably tells us something about the original C-note's deficiencies.
Putting $200 of X-over parts into a $100 kit is hardly a "value endevor", but they sound great and if a guy (or gal) have a nicely finished pr. of C-notes that are gathering dust like I did, I think it's worth it.
