Does anybody know the length of the Ghent Audio NC502MP case with an XLR cable plugged into the back? I'm trying to fit an amp on a shelf that is 14.25 inches deep with a glass front. Deciding between the Ghent option and the 12x12 Buckeye option.
I just measured mine and got ~16 inches from the front edge of the front plate to the rear of the largest bend in the balanced cables exiting the XLR connectors. You may get something different if you're using larger diameter cables as the bend radius typically increases with an increase in cable diameter.
