Designs updated. Trying to get them into engineering's hands for the current batch being produced. If not, they will be 2.5mm wide going forward. Thanks for catching that. Again, broken record but I am definitely open to any necessary changes needed. Also a reason I am keeping small stock of everything so I can update accordingly.
@Buckeye Amps
Hypex amps can generate a good amount of heat in idle and use, especially the higher power modules like the NC502MP. No intake vents are visible on the bottom/back/sides of the case, just exhaust vents on the top.
Top exhaust ventilation slots are most useful if there is intake ventilation on the bottom of the case. It looks possible to add slots around the bottom perimeter, between the modules or low on the sides of the case.
Some underestimate the heat from Hypex amplifiers. Hypex created a thermal design application note to help.
https://www.hypex.nl/img/upload/doc/an_wp/AN_Thermal_design.zip
Further Hypex states in their datasheets "Max output power is time limited due to thermal properties."
https://www.hypex.nl/img/upload/doc/ncore_mp/nc502mp/Documentation/NC502MP_02xx_03xx.pdf
The NC502mp datasheet reports 17W idle power consumption, three of these in a case is 51W idle power before amplification power loss.
For reference KJF Audio hypex based amplifiers implemented a cooling solution using quiet microcontroller throttled fans tuned to be inaudible.
https://www.kjfaudio.com/hypex-amplifiers/
Using passive cooling Apollon and ATI orient the hypex modules vertically in some cases with additional heat sinking and vents directly above and below the modules to promote cooling.
What's the thought to increase cooling which improves power output and expected longevity?
