Bluesound releases 2024 ICON streamer
Hi, sorry, but I didn't have time to read it all, so I was wondering if the Icon also has a remote control??
AirPlay from my iPad M2 and iPhone 15 Pro
Then you could try closing or uninstalling all BluOS apps in parallel to rule out their influence on the volume.
remote control??
Setup an IR Remote, either by teaching your NODE ICON to work with one of your old remotes or by using the Bluesound RC1 remote which works out-of-box.
I will sell it and get myself a wiim or a60. Got fed up with all the troubleshooting. Thanks anyway
Hi All,
Not sure if many people have the Icon yet. I just received mine, it's my first BlueSound device. I cannot get anything to display on the screen. It's possible that I am doing something wrong, but wondered if anyone with an Icon had had a similar issue?
I have tried playing music from both Roon and Qobuz via the BlueOs app, but the screen just remains completely blank. The music plays perfectly.
Appreciate any help.
Cheers
Jonathan
Maybe LCD BRIGHTNESS?
Have you tried a factory reset?
Yep, tried both of those. I think it's defective as on first startup it never showed the QR code for the app download, and has never shown anything since, other than the backlight. I've submitted an exchange request to Crutchfield. Annoying as audio plays perfectly, but the album art was the reason I purchased it :-).
Hi All,
Cheers
Jonathan
Did you use USB or
Yep, tried both of those. I think it's defective as on first startup it never showed the QR code for the app download, and has never shown anything since, other than the backlight. I've submitted an exchange request to Crutchfield. Annoying as audio plays perfectly, but the album art was the reason I purchased it :).
did u try Apple Music on Airplay? The art work display works on my unit
Yep, this is all I see on the front screen (sorry for poor picture quality, but you can see the issue)...
Yep, I called the Crutchfield technical support, went over what I had tried, we concluded it was defective, it’s on it way back to Crutchfield now for an exchange
Does it have a clock display when idle?
It has clock display when idle on an functioning unit. For me I want an option to turn off screen or go into clock mode after a while when playing. As a screen saver. Received mine on thursday and can say that it to me sounds good, but some different nuances to the Wiim Ultra and Eversolo DMP-A6 ME/LHY that I also have. But no serious A-B blindtesting has been held. Some softwareimplementations is better on the Eversolo and Wiim as of now. Bought the Bluesound for Dirac possibillities when that arrives in a software update. More tweaking in settings with the Wiim and Eversolo avaliable at the moment. Which is best for you...the one that fit's your budget and needs. They all sound good.
