The fact is, in the world of SOTA class AB amps it's quite a bargain.
Mine make noise as what I assume are the protection circuits shutting down, but it's not audible through the speakers.Same here.
Well here's my thinking on amps such as the AHB2, which I realize is a bit more expensive. Long time ago, I got sick and tired of buying what "seemed" to be lower cost amps (and other electronics). Turned out that in many cases the lower cost meant addtional replacement costs down the road, and paying a bit more up front was cheaper in the long run. Warranty service, repairability, and overall quality really meant something in terms of dollars spent.I am indeed from the Balkans, although I no longer live there. Which means spending way above my means for something I don't really need is very much in my DNA.
My argument here is not about income inequality, but about putting things into perspective. Power amps do not make audible improvements on the sound after a certain point.
Would I hate on someone with 6 subwoofers in a room? No way - all power to you. I am not counting anyone's money, I am just looking for more consumer oriented no non-sense approach.
With some binding posts, the nut part is removeable. In that case I use a ring terminal crimped and soldered. I also use a copper crush washer to keep the junction air tight.If you elect to use binding posts you insert bare wire from the bottom of the terminal
I just checked, and the Benchmark nut is fixed into the clear plastic housing, so that is not possible. But it is a good idea. My guess is that the AHB2 was designed with a professional audience in mind, so those of us living in regular consumer hi-fi space have to adapt to these little inconveniences.With some binding posts, the nut part is removeable. In that case I use a ring terminal crimped and soldered. I also use a copper crush washer to keep the junction air tight.
The UcDs are for sure the worst, but there are still issues with the NCores. Purifis aren't used much vs Hypex. But I'll put it this way - there's a reason most active speakers use Pascal or ICEPower, despite Hypex performing better.If one is referring to older Hypex boards, perhaps so but I don't believe the newer Hypex or Purifi boards have a tendency to "blow up".
Provide some data on failures if you're this hopped up about it.So 10 pages so far of people claiming exemplary reliability from these amps. Yet not 1 shred of evidence to support this claim. Other than perceived value based on the thickness of the faceplate, mystique surrounding the brand name due to extensive advertising campaigns, and emotional responses from fanboys who overpaid and don’t want to admit they've been had.
I DIY'd some cables for a new Purify amp. I bought a pair of reasonable cables with spade terminations, cut off one end and screwed on a Neutrik speak-on terminal. It was very easy to do. Benchmark's cable may be overly rigid (I don't know how true this is, as I have not seen them in person), but if you DIY you have full control over the cable thickness and rigidity.My only criticism of the amplifier is ergonomic. If you elect to use binding posts you insert bare wire from the bottom of the terminal. This makes insertion awkward as you have to lift up the amplifier, turning it upside down in order to locate the insertion point. The amp is quite lightweight, so it can be done easily. Of course, for most people wire insertion is "one and done' as long as the amplifier stays put.
Speakon connectors are convenient, however Benchmark cables are rather thick and inflexible, so it's not as easy to run them under rugs and in corners like generic Monster-type speaker wire. I understand that the Benchmark Speakon cables have better S/N than generic wire into a biding post, but in my living room it is not anything I've noticed. YMMV
Look at the Soncoz. And there are plenty of Hypex and Purifi integrators that make "entry" level amps for about $1k.Would I hate on someone with 6 subwoofers in a room? No way - all power to you. I am not counting anyone's money, I am just looking for more consumer oriented no non-sense approach.
Well stated. I embraced them when they came along in no small part (!) because I could no longer easily manage or lift the traditional power amps I had been using. We are now renovating our apartment and the small size of the Benchmarks has been quite advantageous.Many of the resident AHB owners here are of an age where they want an end game, 100% reliable, quality built amplifier of superlative performance that doesn’t cost telephone numbers and isn’t the size of a bar fridge which will likely ‘see them out’.
Everyone? I've rarely seen them on sale.
I have not use bare-wires in decades but I have used locking-banana plugs with the Benchmark and not observed any audible differences between them and SpeakOn connections with the same type Canare wire/cable in both.Speakon connectors are convenient, however Benchmark cables are rather thick and inflexible, so it's not as easy to run them under rugs and in corners like generic Monster-type speaker wire. I understand that the Benchmark Speakon cables have better S/N than generic wire into a biding post, but in my living room it is not anything I've noticed. YMMV
It is Canare 4S11.Benchmark's cable may be overly rigid (I don't know how true this is, as I have not seen them in person), but if you DIY you have full control over the cable thickness and rigidity.
One of the biggest lessons from my father: "never worry about, how other people spend their money"
Big thing for mental health and well-being.
Benchmark's cable may be overly rigid...
I think the problem with the pricing is what you’re getting for the price, rather than simply the price. People are using words like “end-game” and other superlatives to describe this amplifier as being superior to other amps costing 10x less per watt. Yet refuse to offer any evidence of the superiority. We already seen the measurements. So are you guys referring to the faceplate? The feet? Some are saying it’s made in the USA. So the PCB’s are populated in the USA? I highly doubt it. More like assembled in the USA just like the US based class D guys assembling class D amps in the USA from foreign populated PCB’s.
If you don’t like what you are getting for the price, don’t buy it.I think the problem with the pricing is what you’re getting for the price, rather than simply the price. People are using words like “end-game” and other superlatives to describe this amplifier as being superior to other amps costing 10x less per watt. Yet refuse to offer any evidence of the superiority. We already seen the measurements. So are you guys referring to the faceplate? The feet? Some are saying it’s made in the USA. So the PCB’s are populated in the USA? I highly doubt it. More like assembled in the USA just like the US based class D guys assembling class D amps in the USA from foreign populated PCB’s.
