Still no word on your end?I have not yet.
The Smyth products simulate speaker sound through headphones. BACCH4Mac HP can do the same in software.
In terms of customer service, I understand that Smyth is not very responsive or reliable, in sharp contrast to Theoretica.
BACCH works with all stereo recordings. Recordings made in natural acoustic spaces work better than studio recordings. Among recordings made in natural acoustic spaces, recordings made using dummy-head microphones tend to work the best.By the way, are binaural recordings necessary for BACCH over headphones? They say on the website that it works with regular stereo recordings over speakers, but only mention binaural audio for headphones.
Is this better than a Smyth Realiser A16? Maybe someone who has heard both could comment...
The BACCH-hs^3 (head-steered sound spotlight) sub-module relies an HOA microphone to create a "high-order microphone beam" that can be steered anywhere in 3D space (using the BACCH-HT-Nav module) by simply looking in that direction, to significantly isolate sound sources in the beam from the background. The BACCH-sme (stereo mic emulation) allows the accuarte emulation of a variable-pattern pair of stereo mics for recording (or low-latency live monitoring) using a single HOA mic. More info can be found on the BACCH-dSP webpage
I tried with some broadband absorbers on the floor to deal with the floor reflection. They make a mild difference. I think the small room factor (and short distance to side walls) put a hard limit on how much XTC I can get. The best result is with listening position equidistant to side walls (which is not quite equidistant to speakers for my room).I've measured crosstalk with and without the sheepskin rug and have not seen much difference. I consistently get 11-14 dB of XTC.
I may experiment with moving room treatments around to see if I can get a higher number.
However, I think that, to get the highest XTC possible with BACCH (which, if I recall correctly, is around 20-23 dB), one has to use beamy electrostatic speakers (Sanders or Quad 57s) or horns.
I'm using the lowest spec M1 Mac mini with 8Gb Ram. It works a bit better than the previous generation Mini that I sold. I would say that the machine is left on 24/7 and there is often a memory error message if BACCH4Mac is left on all that time, as well as audio glitches. All of this is fixed by a reboot.Do any of our BACCH users on the forum know what specification of M1 Mac is needed for optimal performance with BACCH4Mac?
If I replace my current i7 Mac Mini, I will probably look to go with a desktop machine, having had some problems with the two Mac laptops I've used in the past.
Thanks in advance, and happy holidays
Glad it's working with the Genelec 8341, but worried because my 8260 has wider dispersion and focused directivity helps apparently. I wear Some of the initial press seemed to be quoting 30dB of crosstalk cancellation.
Unless the price comes down though, it looks more cost effective to get the $6,000 a pair Polk Legend instead of the $50,000 hardware box.
Has anyone compared the crosstalk cancellation of the Bach SP and a Polk Legend?
