Yes and repeat at 8 times for better SNR.So are you saying if I am calibrating for me (one person in the MLP0, just use one microphone position?
Thanks OCA! I didn't know if maybe I had done something wrong, but I've no issue with turning up the volume a bit more!Audyssey sweeps are supposed to be 75dB at the speaker outputs but that will be effected by speaker efficiency, distance to mic, mic capsule, many factors. No one gets 75dB but 70dB is a bit lower than usual but the target level is not important, you need to turn on the volume a bit more to hear the same loudness level and that's all. If center channel needs extra volume, it could be some dips causing that. Try a different crossover level maybe.
I'd leave all sorts of extra processing off for the cleanest sound production but I guess best tested audibly for your own preference.With Audyssey One should we disable Speaker Virtualizer or does it not matter?
I tried the "single mic point multiple measurements at that location" and compared with the multi mic position that audyssey recommends but just 2 inches from first position. My subwoofer measured 2 db lower using multi-mic position.It really depends on your listening requirement. You'll get the best precision with single mic point multiple measurements at that location or you'll have good precision in a wider area but nowhere will it be as good as the former.
So I've settled on leaving it off. When watching TV there's a lot of dialogue bleeding into my surrounds.I'd leave all sorts of extra processing off for the cleanest sound production but I guess best tested audibly for your own preference.
Wait for A2!@OCA : As for measuring: I tried both. Single point and around MLP with 20-30 cm distances. The single point asked for distance to my center, MLP did not. SP had to revise sub distance 3 times, around MLP did it in one. SP has much less bass and sounds overall less 'forward'.
So with me the around MLP seems to work better, although I optimize for 1 listening position. I used the Harman curve because that helped the bass.
5.2, small room (3,5x3,6m), A One 1.3x, Harman curve.
Any suggestions for making it even better?
That sounds like Dynamic EQ and its uber surround boost.So I've settled on leaving it off. When watching TV there's a lot of dialogue bleeding into my surrounds.
No it was just the Virtualizer which I find strangeThat sounds like Dynamic EQ and its uber surround boost.
Sorry. What is SNR?Yes and repeat at 8 times for better SNR.
Signal to Noise Ratio, more measures or with more samples in the frequency sweep improves SNR. This AFAIK noise floor mantains constant during the measure.Sorry. What is SNR?
Comparing excess phase responses is the more robust way. A1 is doing a slightly better job:One thing I noted today running REW sweeps after A1 optimization is that step response maybe not optimal considering that I have that SW distance limit problem that I have to set Center distance by hand.
After setting my C distance by hand to A1 (1.77m) it inference SW distance to 3.52m which is about right but the step response shows the SW quite delayed so I maxed SW distance manually on Audyssey (7.61m) with a better step response BUT my SW is much near to 3.52m than 7.16m. What I'm doing wrong ?
Red line is the A1 response (3.52m SW distance) green line is manually edited to max (7.16m SW distance). Twetter and Mid is impossible to improve without active XO and breaking my speakers apart, SW being a different driver can; limited to Audessey limits. But my question is, are my Audyssey capture feeding A1 wrong ? (8 points 30cm apart) or there is something else here ?
REW sweeps:
SR_Comparision.mdat
drive.google.com
