- Joined
- Jun 19, 2018
- Messages
- 6,652
- Likes
- 9,525
That actually measures a lot better than other Wilson speakers.
‘Warm‘ and ‘musical’ and ‘analogue’ have no meaning whatsoever.
What about Dark and Bright?‘Warm‘ and ‘musical’ and ‘analogue’ have no meaning whatsoever.
My active speakers have a switch on the back with settings for Dark, Neutral and Bright, so it must be a thing.![]()
I think your post gets to the heart of the matter. None of the speakers you listened to that day are what most here would admire.
This is the Wilson:
https://www.stereophile.com/content/wilson-audio-specialties-sabrina-loudspeaker-measurements
The Harbeth is better:
But objectively not that great compared to far cheaper and far better measuring speakers like the KEF R3.
Yet many swear by those you enjoyed and others that are even more objectively amiss such as all recent B&W speakers, consumer PMC speakers and many many more.
If 'accuracy' did indeed translate into preference we'd all be listening to Revel, KEF, Genelec and the usual suspects.
And we wouldn't be adding a 'target curve' for the sake of preference over reference.
Judging by sales, most people prefer inaccurate.
Btw, I listed to the KEF R7, and the KEF Reference 5, as well as Legacy and a few other brands. I preferred the Harbeth over the R7, but I think the Ref 5 were excellent. The Harbeths seemed bigger than the R7, somehow. All subjective, time between switching, etc.
It isn’t just that I may have preferred “inaccurate” (although the Harbeth is less inaccurate than it is lacking in good directivity behavior, which is slightly different). I also think auditioning preferences and preferences for long-term use can be different. I certainly learned that in a formative early audio experience I recounted here - http://andrewhofer.com/blog/2020/11/10/blind-listening-tests-introduction/ .
How do they sound? What other monitors did you consider before buying them?So i just measured my ATC SCM50ASL classic's - don't look too bad when measured in line with the mid dome. Not so good when measured in line with the tweeter, but i listen at mid dome level.
Details:
Left Channel only, measure in room using 20-20kHz sweep
Motu M2 ADC/DAC - loopback calibrated
iSEMcon EMX-7150 Microphone - factory calibrated
Mic aligned to mid dome, 250mm from dome surface
REW Software
So i just measured my ATC SCM50ASL classic's - don't look too bad when measured in line with the mid dome. Not so good when measured in line with the tweeter, but i listen at mid dome level...
Mic aligned to mid dome, 250mm from dome surface.
What do you think about all the negative comments about them not being accurate around here lol.
With a baffle size of 71.6 x 35.1 cm, 25cm measurement distance is too close to the DUT. A measurement at a distance of 100cm (maybe 70cm) and with gate to fade out the room resonances should give more realistic results.
The rule of thumb for the measurement distance recommends a distance of three times the largest baffle dimension (in your case the diagonal), in order to definitely capture the baffle influences completely - which usually cannot be realized in normal rooms.
It would also be important to make at least one or two angle measurements (e.g. 30°, 60°) to get an indication of how smooth the horizontal radiation is.
Ok mate will give it a go. Do you rotate the mic for the angle measurements so it points toward the driver radially or 'translate' it so it's aligned with the horizontal and vertical planes.?
On mid dome axis & gated at 5.9s (only 1m from the wall so reflect still in there). Can't be sure everything is aligned properly, need a laser with H/V.
Could you also measure them approximately in the middle between the mid and tweeter, as maybe then they will measure smoother?Measured on mid dome axis 1m from driver & gated to remove early reflection:
