Recommended Pro Studio Monitors?
I find it kinda baffling the notion that op thinks he needs better speakers when his room is not properly isolated, nor does he use software for room correction properly, and the notion that they think getting better monitors will fix phone translation.
Hmm, rightly or wrongly, that wasn't exactly what I took away from their post. OP is hiring an acoustician to do room treatment, has a budget of $9000 for monitors, and is wanting them for pro use, so some form of upgrade from Shapes does seem reasonable enough to me. It'll be a contributing factor.
I do completely agree though that room correction software/hardware needs a high priority when it comes to mix translation from all but the most perfect of rooms. I'd generally rather work on cheap speakers with correction than expensive ones without.
My experience is sort of the opposite, when the monitors are good enough, you only correction in the bass. When they're not, full range compensation still can't fix that.
Yeah I don't necessarily mean full range correction. And when I say cheap, I mean something like a Kali IN8. Possibly a JBL 30x, just about.
Hello, I've been reading through the various forums posts here with great interest and already shortlisted a few monitors but would like to ask the forum members now.
I've seen this type of thread a few times before but answers change with time, budget and specific situations / preferences.
Here's my situation:
I produce music and would like to upgrade my studio monitors at some point in the future (within the next 18 months). Currently working on a pair of Focal Shape 65. They are not bad at all but I always think I could do better because my songs are not translating that great on mobile phones.
I'm working in a home studio with okay acoustic treatment. I produce, mix and master everything myself but also send things off to a great mixing & mastering engineer sometimes.
The room is around 20-22 square meters / 215-236 square feet. The exact measurement escapes me at the moment.
I am going to hire a studio acoustician in the future and have him measure and treat everything to higher standards but the current treatment is def. okay. Just stating this because I've seen a lot of replies like "invest into acoustic treatment rather than new monitors" on other forums and I def. pay attention to room acoustics.
I guess the question is really simple:
What studio monitors do you recommend for professional music production?
Of course, they should be neutral, flat and help me make songs translate perfectly on other systems.
Because I am renting, I can not install speakers into a wall or build a second wall.
Budget is 9,000 USD / 8.000 EUR / 12,600 CAD / 14,250 AUD.
I don't know if is necessary to max out the budget or if speakers that cost less will do the job just fine too. For example, I know that a pro studio ( I think it is run AVID in California ) uses the Kali Audio IN8 v2 speakers for their surround sound studio rooms. Those are quite affordable. These were also recommended to me by another pro producer but I've also seen many producers rocking the Yamaha HS series, which I dislike a lot. So, just need some quantity of recommendations too. Maybe, if you have the time to spare, you could give an option that is around the max budget and another option that costs less (like 4,500 USD for a pair).
Genelec and Neumann get a lot of love here but I honestly don't see them as often in pro studios compared to ATC, PMC, Auspurger, Barefoot and some others. After watching a bunch of studio tours and equipment posts from 2025, I've noticed that quite a few high end engineers use Amphion monitors, especially the Two18 model. I know this forum is more aimed at general audio enthusiasts rather than music professionals but I've already found some great info here and hope to get some recommendations.
Thanks in advance.
Have a look at PDP MUM8 three way. £5-7k Direct sales so half the price of similar quality studio monitors. Hypex Digital amp packs. Purify bass driver and top end bliesmer mid and treble drivers. Modular and upgradable. Designed and built by uk studio professionals. Designed to translate very well. Great youtube channel too. PresentDayProductions
Review and measurements here,
Usually it is that the bass is too strong and there are problems in the mids / upper mids and/or highs that are glaringly obvious when listening on a smartphone but are hard to hear on the Focals even when knowing what to listen for. I resorted to turning up the hardware EQ for the lows and highs on the Focals to make them more prominent but still they lack detail that I can so easily hear on the phone.
Stay away from any bass producing monitor in a badly sounding room.
Auratone 5Cs and a decent pair of headphones to check the low end. The more bass heavy the genre, the more helpful they are.
With your budget you can certainly make a huge upgrade over your Focals, but I'm not sure this is really what blocks you from having good translation
In your position the first thing I would do is to get a measurement microphone (UMIK for example) to really get the best from my system (take a look at the tutorials in the Room Acoustics section of the forum)
And then if you still feel held back by your monitoring look at upgrading, but I think it's worth trying a 100€ solution before buying 8k€ of speakers
And the mic will also be useful with the Kali if you choose them
thanks for this. i think learning how your room responds is a great place to start.
You dont need those high amount of money , because actually only a chip do the job to translate its depends on wich chip or kind of technology likee the Legendary Yamaha NS10 they level up around 1500hz is the mixing engineers trick to expose the negative frequencies. Actually everything you do on those NS10 and sounds good then will sound good everywhere. Its just an eq settings. If you need you need because yours are old and you dont trust them anymore on mixing , we need 2 kind of speakers one or two way for mixing one way better like mixcubes, and 3 way or 4 way to produce and master.
I don't understand ???
Nope. Mixed for the NS10 a recording might not sound offending on neutral speakers but also not really good, since a part of the important mids is missing.
If you use EQ to tame the mids of the NS10 you can also use a neutral speaker in the first place.
See above. Mixing on neutral speakers and then changing the sound so it does not sound bad an bad speakers does not lead to excellent sound on all speakers. You might have a look at the "circle of confusion" described by @Floyd Toole.
And all the bass as it rolls off around 90-100hz.
Hadn't we concluded a long time ago that NS10s were a tool for one particular upper midrange area and other better-balanced monitors were/are used for the rest of the spectrum? Modern studio installs I see in pics don't 'feature' NS10s at all now...
Something along those lines. I still see them quite often, but they're not really needed if you have a relatively neutral monitor to begin with.
The frequency response of Auratones and NS10s is veeery helpful, but the way more important aspect is their fantastic transient response. It's that combination why they brutally reveal any weaknesses.
