I do, actually. They were originally written for the now-defunct Resolution magazine.Do you have a link to those measurements?
That first chart looks quite nice! Flat enough and an almost total absence of distortion above 300hz... Outstanding. Shows what you pay for with an ATC
Anything about pair matching on ATC is overblown imo... A huge part of the cost of an ATC are the bespoke, spare no expense drivers they use. A dome mid that can play like that from 380hz on up... Spectacular. Starting with parts like that, everything will just naturally fall into place without any undue effort on their part.
I do not like Neumann or Genelec because I have seen them.And that can be said for Neumann and Genelec speakers, too. Even if both of them are considered top-measuring studio speaker brands, there are still people who prefer one over the other by a big margin.
What people here should know is that no matter what brand they prefer the sound of, most of them are measuring good enough to be within the ballpark of neutrality, and that goes for ATC too. The thing that separates them is down to personal preferences.
So personally I'm no loyalist to any brand. I'd encourage you to give the big 3 ways a listen at some point, just to see if you like them. That said, the 3 ways bigger than the scm40 are very large indeed. The SCM50s are a hair larger than KH420s, which by no means are small speakers.I do not like Neumann or Genelec because I have seen them.
Sorry, after it measures well & sounds good, it also has to fit in with my aesthetics (at multiple homes that have similar aesthetics.
From pictures, the ATC would fit the aesthetics part.
But since you push this so hard, I will never seek one out.
I like my choices that I have & see no reason to change.
Push: then I absolutely will not be swayed.
Present the information & I'll look at it & check it out.
Maybe people like you are why it's not so popular.
Overall, I prefer 3 ways (& more ways) but I rarely see them tested.So personally I'm no loyalist to any brand. I'd encourage you to give the big 3 ways a listen at some point, just to see if you like them. That said, the 3 ways bigger than the scm40 are very large indeed. The SCM50s are a hair larger than KH420s, which by no means are small speakers.
ATCs are fine, generally voiced a little warm if anything. Probably closer to a Revel than a Genelec, all things considered.
I think the passives are a mistake, they need a lot of amp (the sensitivity is generally 85dB or lower) and the actives have a bit better integration. Unfortunately their amp packs are power suckers (high idling AB) so they probably should be turned off when you aren't using them.
View attachment 460624View attachment 460625
Totally different style of cabinet
Which should sound and measure better?
They've intentionally made that dip in the response to compensate for the off-axis flare.A few days ago, I made directivity measurements (0 to 90 degrees, gated) of my ATC SCM40 v2, and as expected, there are a bit of disturbance in the crossover region of the midrange driver to tweeter.
The interesting part is that ATC seems to have used that to their advantage, as the amount of directivity mismatch is regaining some of the lost on-axis energy in exactly that crossover frequency area. I know this because a few years ago, I did some small EQ adjustments and raised that area to an on-axis more flat response, but that made the these speakers sound a bit too bright.
I don't see this as a problem, as these speakers already sound perfectly flat in the listening position.
It's an old school way to improve the power response, one that is generally better dealt with via dispersion matching.
It isn't as though ATC is unfamiliar with the concept - the mid dome has some matching. You wouldn't even need a big guide like on Neumanns or Genelecs, something sized about like a Seas DXT would be enough at the Fc they use.
There's a myth that ATCs are more "musical" and less analytical
Is that true?
LOL no. They're maybe a little more laid back than a Gennie but they tend to be very detailed especially in the range the mid driver covers.There's a myth that ATCs are more "musical" and less analytical
Is that true?
to me Genelecs are more fatiguing. Or, rather, takes less time to get tired compared to ATCs. That's from about a year experience in one room with 8351s vs 50s next to each other. But Meyer AMIEs are even faster in causing my brain to tell me "shut that noise off!" FWIW.There's a myth that ATCs are more "musical" and less analytical
Is that true?
Fatiguing as in more detailed? Or just bright?to me Genelecs are more fatiguing. Or, rather, takes less time to get tired compared to ATCs. That's from about a year experience in one room with 8351s vs 50s next to each other. But Meyer AMIEs are even faster in causing my brain to tell me "shut that noise off!" FWIW.
Fatiguing as in getting tired and can’t make decisions/enjoy the music. Level of detail is about the same. HF has nothing to do with it.Fatiguing as in more detailed? Or just bright?
Could you post them here, am sure many would be interested.A few days ago, I made directivity measurements (0 to 90 degrees, gated) of my ATC SCM40 v2, and as expected, there are a bit of disturbance in the crossover region of the midrange driver to tweeter.
Such "tricks" are done since more than 50 years from experienced loudspeaker designers when a directivity mismatch was the ruleThe interesting part is that ATC seems to have used that to their advantage, as the amount of directivity mismatch is regaining some of the lost on-axis energy in exactly that crossover frequency area. I know this because a few years ago, I did some small EQ adjustments and raised that area to an on-axis more flat response, but that made the these speakers sound a bit too bright.
Could you post them here, am sure many would be interested.![]()
