Ascend Sierra-1 V2 Speaker Review
Rate this speaker:
    Votes: 2 0.5%
    Votes: 9 2.4%
    Votes: 55 14.7%
    Votes: 308 82.4%
I want the voices to sound better with more emotion. I'm not sure if this is possible :) . I've already listened to the Evoke 10 and AE500 speakers and they sounded better. But i cannot test the Sierra speakers here in Europe.
I think Ascend speakers add less coloration then other brands. If you like how the original recording sounds, and rest of your system is neutral, you'll probably like the way it sounds with Ascend speakers. However, asking a speaker or any component to give a certain type of sound to every recording seems like "audiophile" speak.
I'm not sure what exactly more emotion means, but those Wharfdales do appear to a have a dip in the midrange that might reduce vocal clarity and presence. particularly if you have them on a desktop and are getting a lot of 'floor bounce' off of the surface. The Sierra speakers you mention do not appear to have this same voicing and would likely provide better vocal presence in your scenario even vs the Wharfdales with EQ. that said, as a general question, have you attempted to EQ your current speakers and see if they sound better to you?
I am still not sure if the Sierra 1 V2 speaker would be an upgrade for my wharefedale diamond 12.1 speakers since they also have a 5" woofer.
I had both speakers, and the 12.1 is very nice for the price, but the Sierra 1-V2 is easily a class above.
If you want more vocal emotion, try something like classic Rogers speakers. I recently found a pair of LS6a's, and they have been described by some as a poor man's Harbeth.
Emotion=Distortion
The large dip around 3.5 kHz is not admissible for a speaker labelled as NFS optimized.
Something is going wrong with this design.
@amirm , just a simple question: how the 3.5kHz large dip can disappear in al measurement but 2 of them?
As the worst case scenario needs to be taken, this large dip is a product weakness but for an unknown reason hidden in most measurements.
Is it a deliberate action or a measurement error?
An explanation would be welcome.
There is nothing wrong with the design of the Sierra-1V2. You should not be using a CSD waterfall plot to evaluate frequency response. CSD plots are for examining resonances. All of the many different frequency response measurements should be used to evaluate frequency response.
You see a dip in the CSD fundamental because the NFS is not capable of producing anechoic CSD plots unless the user is also using an additional module for the NFS known as ISC (In Situ Room Compensation), and even then it is not truly anechoic. This NFS module did not exist when Amir first started measuring speakers, it is also an expensive add-on. We own it, but don't use it very often so I am not sure if it is worth the expense for Amir.
As such, in order to minimum room effects in the CSD measurement, Amir takes this measurement using a mic distance of only 1/3 meter (about 1 foot) with the mic at the reference axis (the tweeter) At only 1 foot away, there isn't enough distance for the woofer and tweeter to properly blend so you see that dip at the crossover frequency. With Sierra-1V2, you need ~18 inches of distance for the tweeter and woofer to properly blend.
Again, you should not be trying to evaluate frequency response from a CSD measurement's fundamental.
Hope this explains it for you!
great explanation, i am always learning new things in the hobby and now i learned another new thing..
To be fair, there is a small, somewhat broad Q dip in the on-axis FR at around 3.5kHz which is not present in the estimated in-room response (showing that the speaker is optimized for that, similar to Revel). Also, Amir's EQ has a 2dB bump at 3.2kHz which is part of what he found to improve the subjective sound. Doesn't mean there's a "problem" with the speaker, of course. Asides from the rather low sensitivity and power handling (though that's an issue for pretty much all two-ways in this size class), this is an excellent speaker.
How are these at low/moderate volumes in an apartment?
Great! These speakers are simply very good value for money. The base for example goes pretty low and is "punchy" for its size.
This is a review, listening tests, EQ and detailed measurements of the Ascend Acoustics Sierra-1 V2 bookshelf speaker. It is on kind loan from a member and costs US $998 for a pair ($948 on sale).
The finish is nice enough. The cabinet feels quite heavy for its size and especially in the front indicating beefy low frequency woofer. I do wish the grill was magnetic though rather than plastic tabs that are more delicate. I did my testing without it and would have been nice to not see those holes.
Back panel put a big smile on my face:
See the "NFS Optimized" tag! A couple of years ago I tested an Ascend speaker and found the performance wanting. Needless to say, the company owner/designer, Dave, was not happy. But instead of taking his anger on me, he reached out to Klippel to learn more about the Near-field Scanner I had used to test his speaker. He quickly ordered one and started to revamp his speaker designs. We have seen an example of this in electronics area and benefits it brings to the company and its buyers. Such is happening here in speaker design.
It was with nervous fingers and ears that I went into this testing. Yes, there is another set of measurements out there but my testing differs enough to merit testing a user purchased sample. So here we go.
FYI, I ran the measurements by Dave (company designer) last night and they correlate very well with their internal measurements. There is a tiny bit of deviation in bass well below response of the speaker which is not material. And at any rate, I measured the speaker at 59 degrees F which tens to damp bass response a bit.
If you are not familiar with the measurements you are about to see, I highly recommend you watch my video on understanding speaker measurements:
Ascend Sierra-1 V2 Speaker Measurements
Let's start with our speaker frequency response measurements as usual:
On axis response is quite good with only small variations here and there which my higher resolution scan brings out more than other measurements. We see a couple of small resonances below 1000 Hz (see below for cause). And a dip around 3 kHz. But really, these are very minor. What is very remarkable is the early window response in dashed blue. It is so smooth and nice after 900 Hz. We can see that in detail in early window response:
This is what you get with closed loop measurements and excellent engineering folks! All the reflections so nicely sum together, likely better than any speaker I have measured! This means the speaker will be very room friendly and easy to place. To wit, putting everything together we get an excellent predicted in-room response:
Amazing that this is achieved in a passive speaker without DSP!
Close-in measurements of the port and driver show resonances very well suppressed:
Putting on our hyper scrutiny hat, we do see minor contributions from the port resonances in on-axis response. But as judgements go against countless other bookshelf speakers, this is excellent showing.
Sensitivity of the speaker is low side to get that deeper, flat extended response and that brings out issues with the woofer not being able to handle high SPL very gracefully:
But keep that thought when I evaluate this in listening tests.
I showed this tri-power sweep in the last speaker review and folks liked it so I repeated it here. Alas, 102 dBSPL was causing the speaker to nearly blow its mind so it is well outside of its design envelop:
The difference between 86 and 96 is too minor to be of concern.
Horizontal directivity is fairly well control especially considering that we don't have a deep waveguide:
The lack of waveguide is what allows the wider directivity which again, I will evaluate in listening tests.
Vertical directivity has the typical issues we see in non-coaxial designs so nothing of specific worry here:
Impedance is unusually high in this day and age, making the speaker an easier drive although lack of sensitivity means you still need lot of power on tap:
Here is our waterfall and step responses:
Ascend Sierra-1 V2 Listening Tests and Equalization
As I noted at the outset, I was a bit nervous about going into this aspect of the listening test. Would I like a speaker that is fully optimized with NFS in listening tests? Would I be biased to like it regardless? I always start with my female tracks and here, the response left no room for complaining. Sound was balanced with no aspect of the speaker standing out until a bass note activated a room mode which I corrected with my usual 105 Hz filter. I then listened some more. Am I liking this sound? Answer was, that it was pleasant but not exciting. Measurements showed that speaker was optimized for off-axis and PIR more than on-axis. Let's see what happens when we reverse this situation and flatten on-axis:
I started with Band 2, filling that small treble dip. That very nicely brought female vocals forward. That encouraged me to then pull down the two port resonances. Yes, the filter strength is very low but it was enough to change the character of the upper bass. Once all the filters were in place, I performed AB tests and boy, I really, really liked the results with this EQ. We are talking about subtle differences but the sound was more open and clarity was improved.
What was really nice was the spatial qualities of the speaker. Its wide directivity meant it projected a large halo around the single speaker I was listening to. This, combined with the tiny tweaks above made for stunning presentation at times. Some of my reference tracks sounded so good that my jaw fell on the floor!
I was expecting to hear distortion at elevated volumes but this did not materialize. Even at elevated playback levels where I could see the woofer moving back and forth, I could not detect any degradation.
The problem area with respect to distortion is in deep sub-bass region. Most bookshelves won't bother to play this range. The Sierra-1 V2 doesn't shy away and attempts to play them at full amplitude resulting in fair amount of distortion. Fortunately this only shows up in my "speaker killer" tracks. On all others, even deep bass was reproduced exceptionally well.
When I was offered this speaker for review at first I thought, well it was measured and tested elsewhere so maybe I need to pass. I am glad I did not and performed the review. We got to test a random production sample and managed to extract some other insights about the speaker. In a nutshell, the design is heavily optimized for off-axis and predicted in-room response which makes the speaker very room friendly and is critical in listener preference studies. The on-axis response which while excellent in this product class, shows a bit of variations. My informal testing shows that slight corrections to response yields subjective improvements in listening. Whether this translates to others or not, I can't say.
The high level picture is that company has made an incredible investment in instrumentation and optimization of its product and it shows. Likely ton of effort has gone into scan after scan to produce some of the best measurements I have seen. Having a Klippel NFS is one thing. Putting up with multi-hour scans for every test iteration is another.
It is my pleasure to add the Ascend Acoustics Sierra-1 V2 speaker to my recommended list.
I can't believe that even with such a flat response in the room, they still resort to using filters.(EQ settings)
Is it some kind of illness like OCD or It's clearly not straight in the room?
Obviously, there is a problem when resorting to using filters(EQ)
Does anyone find this response strange?
Obviously it's not straight wherever it's measured?
Probably none of this is audible during normal listening, except for a slightly more pronounced bass?
Try to look at that out of the chamber and really not relevant regarding placement measurement graph with one's above it regarding THD as it simply try to highlight the difference (compression).
whats wrong with tinkering..?
Who are "they"?
In any case, here's what can be improved using EQ (dashed=stock):
Lastly, even if the speaker were flawless, EQ would still be strongly recommended, since your speakers are only half of the equation. Room acoustics being the other.
No, that's a close-mic'd, echoic response measurement that Amir performs for convenience.
It is not representative of the speaker's true response.
Who are "they"?
By "they" I mean the reviewer who measured it of course.
That FR is certainly not close mic because you clearly see the entire frequency response and it's certainly not a speaker with one full range driver or?
Ok in your picture I see bass extension, which is slight and may be audible?
But other that that I see 1 db up or down in two or three places in FR.Do you really think you can tell the difference when listening to music or movies?
I certainly can't and I have a speaker three times worse than this one and that's why I feel sick when I listen to Erin's reviews where he praises his golden ears and hears small dip of about 1 db or less at 190hz.
And he listen in untreated room so that dip would be the smallest problem he has especially in bass region where room dominates, not to mention that we human beings have very poor hearing of low tones where there are numerous studies on this see Fletcher and Munson curves...
Can you link to the list of things admissible/not admissible for a speaker labelled as NFS optimized? I was not aware of such a thing.
