norman bates
The lx goes deeper on graphs..
www.audiosciencereview.com
and from TurtlePaul on the thread above post 91
"I own Revel speakers. They are very good. I have owned Ascend speakers in the past. If you look at Madisound, you can see the Seas Prestige Titan drivers, which Ascend uses a derivative of for the LX (with motor changes to the woofer) and the SB Acoustic aluminum drivers which Revel uses a derivative of in the Performa 3 series (with custom tweeter waveguides).
The Ascend Sierra LX and the Revel m106 are both 6” 2-way speakers which you can buy for <$1,500 a pair right now. On Madisound, drivers in the Ascend are $200 for the woofer and $93 for the tweeter. The drivers for the m106 are $85 for the woofer and $55 for the tweeter. You can see a similar parts list for Philharmonic (which I have also owned) which has a 3-way with ribbon tweeters for less than $2k. and can sell a 2-way bookshelf with the ceramic coated SB drivers for $850.
That is the difference of one needing dealer mark-up and one not. In my mind, audio dealers are going the way of travel agents."
I guess I'm curious if the ascend would be more revealing (do we have a graph for that ?) than the revel m106..............................
Like micro detail.................
Ascend Acoustics Sierra-1 V2 - Review & Measurements by Erin
If you go to spinorama and compare the Sierra 1 v2 to the LX, you can see exactly where the LX "thumps" the 1 V2.
