Buckchester
- Joined
- Sep 30, 2021
- Messages
- 192
- Likes
- 316
Well duh, it's because of the plankton. PLANKTON!
I don't think there is such an emphasis. There is gear measured and the distortion is noted. This is a round about way of saying the site only cares about SINAD. It isn't true. All of which appears to be drawing attention away from you doing this simple listening test. Which is simple, and simply done. Yet you are having difficulty making it happen. No CD players, no streamers, no laptops and DACs, no friends with such devices?You are sidestepping my question. We all know that I claimed and claim most of what you're saying in this quote. That has nothing to do with the question I asked.
So I'll try again: I've noticed that on this site in particular low distortion is held in high regard. But at the same time it seemed to be acknowledged that it generally isn't audible anyway. So what I'm asking is why is there an obvious emphasis on distortion? It seems a bit contradictory to me.
One thing that has occurred to me though... If the distortion really turns out to be inaudible (as brightness), why be concerned about it to the degree we often see on this forum?
Nothing to be concerned about if you have a fat wallet.One thing that has occurred to me though... If the distortion really turns out to be inaudible (as brightness), why be concerned about it to the degree we often see on this forum?
No, this site is concerned with the misrepresentation of distortion and it's audibility. With the understanding that in most circumstances it's inaudible.You are sidestepping my question. We all know that I claimed and claim most of what you're saying in this quote. That has nothing to do with the question I asked.
Emphasis added.No, this site is concerned with the misrepresentation of distortion and it's audibility. With the understanding that in most circumstances it's inaudible.
Please, don't misrepresent what the actual stance is by some illogical wordplay. Observations that something is below a threshold isn't the same as being obsessed about something, or whatever aspersion you are casting.
Yes, there are SINAD chasers here, I tend to ignore... Although most gear I consider good, useful, and reliable happens to also have excellent noise and distortion. So it's no surprise that I if I don't believe the hype about "certain levels of HD have xyz sonic signature that justifies a purchase", it's not the same as having "an obvious emphasis on distortion". It's actually totally the opposite.
I don't generally hang out with other audiophiles. My free time is more likely spent on old bicycles. I have CD players of course but in order to do this a program has to be loaded on the computer that is also playing the files in comparison, so a CD player isn't helpful unless there's something I'm not understanding... That program keeps track of how many times you made a correct or incorrect choice while the files are being played.I don't think there is such an emphasis. There is gear measured and the distortion is noted. This is a round about way of saying the site only cares about SINAD. It isn't true. All of which appears to be drawing attention away from you doing this simple listening test. Which is simple, and simply done. Yet you are having difficulty making it happen. No CD players, no streamers, no laptops and DACs, no friends with such devices?
The question being asked is, "Is the distortion audible?" It isn't to me, but Ralph has continually claimed that it is to him (and others), so here's a way to test that claim.There are a lot of subjective factors in the appreciation of audio, and they are hard to define with the actual science as the vary from person to person. But this site is not really about that, it's about testing the objective side of things and seperate the good engineering from the bad. Sinad is one factor of the many in that. If you see the tests of Amir, you see that he tests a lot more than noise and THD.
But it's not because it's tested and found technical good that you will like it. Many like a bit of a certain distortion in their sound (for various reasons) and other deviations of perfectly flat neutral low distortion. And the Adcom amps, altough technically quiet good have their fans and haters. I don't like that amp also not, probally on subjective reasons just like i don't like Genelec. But i will recognise that they are technically very high quality, the dislike is subjective. And i will recognise that my tube amp is a noisebox compared to modern clean amps (but I love the noise it makes).
There are studies about that subjective appreciation, and those show that most like it clean neutral low distortion. And the tests here show that that does not have to cost a fortune and that many expensive who claim superior quality are not. That is the role of this site, not telling you what you should like. Liking is by definition subjective, altough objective tendencies can and have been proven by people like Floyd Toole and Sean Olive (both working for Harman). But those are generalised tendencies (good for marketing and so), not the rule what you should like. But if you don't know what you like their standard (the harman curve and so) are a good start to find that out and this site helps you to find the gear that really follows that, or deviate from it in one or another form. Nothing more than that.
It's easy to test. Can people who claim the audibility of a class of distortion profiles actually hear the difference with and without distortion? Without peeking.it's hard to test
Easily measurable and this is what Amir does... he measures the most obvious and easily verifiable aspects under certain loads in a comparable way.Why is there such an emphasis on measuring things like amplifiers and other “ essentially solved” types of audio gear, if the measurements routinely tell us the distortion is inaudible?
In general, ASR is an exception in the HiFi industry. The so-called HiFi press, countless web forums and YouTube videos spread complete nonsense. The information (disinformation) they spread is that there are significant differences between everything from amplifiers to network cables and network switches. This is mostly complete nonsense. It's about exploiting the subjective nature of our hearing and playing on expectation bias. Basically, it's about FUD with the aim of getting consumers to constantly look for and buy new gadgets. ASR's measurements can be seen as a ritual where a basic message is repeated. These are objective facts. There is no other objective.Why is there such an emphasis on measuring things like amplifiers and other “ essentially solved” types of audio gear, if the measurements routinely tell us the distortion is inaudible.
Something that is not fully comprehended by most casual readers visiting now and then but is known to regulars interested in the measurements.
