- Joined
- Jan 15, 2020
- Messages
- 6,903
- Likes
- 16,917
Low order filters enhance though vertical directivity problems (lobes).Low order filters, which help blend directivity characteristics, are much easier to implement due to delay.
Any particular reason to pick up the Disco models over the original Peerless versions?ScanSpeak Discovery sort of level.
MY understanding is that the Visaton and Monacor waveguides are similar in profile, but the throat transitions are different. Does anyone know what that difference is?
Also, in the hypothetical SB 3-way, I think the 23NRX is a better choice. TSPs aside, the material choice is not going to be a major factor with such a low expected x-over point, and NRX is cheaper than the NAC/NBAC.
I have used these Sure Electronics or WONDOM brand amplifiers in many projects. Parts Express has them re-branded with red PCBs and makes nicer user manuals for them. I bought mine before Parts Express started selling these but I would prefer to source the boards from them since it is the same price and comes from their US warehouse rather than China direct. I have also used their Bluetooth equipped amp boards but I would not recommend them due to nasty ground loop noises and DC offset when using the supplied volume pot.
I turned this old General Electric speaker into a battery powered bluetooth speaker using the 1x100w amp with DSP (equivalent to the DSPB-100) and the 1x100w amp without DSP (WONDOM AA-AB31184). As you can see they are mounted on the KAB-AB L-type Aluminum Bracket using the
PC Board M3 Standoff Kit. I have used the 1x100w and 2x50w amps without DSP for a few different bluetooth speaker projects and have been quite satisfied. I would bet that their measured performance is mediocre but they sound perfectly adequate to me. Thankfully there was no ground loop issue when powering both amplifier boards from the same power supply. The gain of these two amps is different but once I had the volume properly set, there didn't seem to be any audible difference between the amps while I was deciding which to use for woofer and which for tweeter. Noise levels weren't super low but they were about on par with my LSR305's, although I was using the not so efficient Peerless DX20BF00-04. After this project I realized it would have made more sense to just use the 2x50w amp with DSP for a 2-way speaker.
This is an old XAM 4E speaker that I am turning into a self power speaker with built in phono preamp. I'm using the 2x50w amp with DSP for this one with the same Peerless tweeter and the Dayton Audio DC160-4.
All of these DSP units from Sure Electronics use the ADAU1701 chip which is the same part used in the standard miniDSP 2x4. I wouldn't call the miniDSP 2x4 simple to use, but the Sure Electronics units are even less user friendly imo. First of all they require the Dayton Audio DSPB-ICP1 for programming, which is an added cost. But more annoyingly they use the SigmaStudio software for programming which is not intuitive. Now, once you have learned to use the software and have created the perfect crossover, it is easy to save that configuration and share it with others. However just getting the program to recognize the DSP board and getting the configuration properly synced can be a pita. I wouldn't consider this a deal breaker but someone will have to create a detailed guide if this project is meant to be shared with a larger audience.
Also the Dayton Audio DSPB-K is interesting but when used with the Dayton Audio DSPB-KE i/o board it only gives you 3 outputs. I'm not sure if the DSPB-K board is inherently limited to 3 outputs but it's a shame the connection board designed for it is limited. When you consider the price of these two boards together along with the price of the DSPB-ICP1 programming board, and keep in mind that it only has 3 outputs, I would prefer to use the miniDSP 2x4 Kit. And I would not be surprised if the miniDSP has better measured performance when you look at the supporting circuitry around the ADAU1701. The DSPB-250 is definitely the sweet spot when it comes to price vs features seeing as you're getting a 2x50w amplifier along with two more outputs from a 3.5mm jack. Pairing that with the 1x100w amp without DSP woud make a lot of sense for a 3-way speaker. And then there's still an extra output for a subwoofer if you want it, although I think it would make more sense to use a preamplifier or processor with subwoofer outputs before the speakers.
Hifiberry have a fair bit of stuff about using SigmaStudio for the BeoCreate and DAC+ DSP, and FreeDSP may also be helpful. Porting some of their software may be viable too - HifiBerry's via a Pi, or Auverdion's web gui on an esp32 maybe. That's going somewhat beyond an initial prototype though.I agree that the minidsp stuff is a bit easier to program, I looked at sigmastudio and it doesn't look very inviting. However, I'm fairly confident I can figure it out.
Getting back to driver choices, I think the biggest points of agreement that have to be arrived at are
- budget
- acceptable cabinet size
- (maybe) topology - sealed, ported, PR?
My concern about a sealed alignment is that output is ultimately limited and it needs power, at least if you're trying to stay small. If sealed is really desired, the RSS210HO probably deserves a look - not too much more expensive than the SB23's, but more xmax and does ok in about 0.5 cu ft. PR alignments can work well for small boxes, but are trickier to get right. The Dayton DSA175 prs are pretty cheap though, so I may putz around and see whether I can model up something that might be an interesting alternative.
@hardisj can you chime in and give your advice on woofer selection? We're designing trying to design an active/DSP speaker, and we're thinking of using a sealed 8-10" woofer for the low end. Requirements are smooth response to 500hz, reasonable extension in a smallish cabinet, under $120 or so, and high output. I know you used to measure these things so your intuition is valuable here.
Ok, throwing a potential woofer option out there. A single Anarchy woofer ($66 from diysoundgroup) with 2 Dayton DSA215 PRs ($20 ea) in 19L will be flat-ish to 30Hz and produce 100dB with 80W input before the PR excursion becomes a problem. 150g added weight to each PR, but I'm not actually sure they will support that much weight. 17L and 100g each looks good to the mid-30's and gets you 104dB @100W (modeled with WinISD, which I believe is half-space)
this is the 8-ohm Anarchy. Normally I'd go for the 4-ohm to take better advantage of amp power, but full T/S params for the 4-ohm aren't available.
$120 a driver (or less). I like the Dayton RS270p, for example, but if we can get an 8" with enough xmax to beat it that might be better.$120/pair or $120/driver?
Up to 500hz implies midbass passband to me (i.e., 70hz-500hz). Is that correct? IOW, this isn't a subwoofer, right?
I always default to Scanspeak and SB Acoustics. Scanspeak's Discovery line is what I used in my car. 10 inch midbass covering 80-300hz. Around the $120/driver mark.
But, I'll wait to get the answers before I throw out any suggestions.
A few thoughts. Dsp enables designs which would be impossible to realize with passive components. However, you can keep almost all the advantages of an active design by going to a hybrid design where W/M is an active crossover, and M/T is passive. The latter passive network doesn't need to be too fancy, since you can apply PEQ to that channel, so really it's just a matter of getting the crossover integration correct.
Going in this direction opens up some possibilities for amplification, as well, since it is a bit easier to find a stereo amp to stick in a speaker than it is to find 3 channels of amplification.
Did you send them to Amir, or somewhere else? Based on the datasheet, the amp itself is 'ok', although doesn't actually hit the power targets (a lot of these chips are rated at 10% distortion). If it uses the built-in converters in the ADAU dsp, it should be similar-ish to the original non-HD minidsp units - so 'ok, not great'.Having said that, if the tests on the 50x50x100 module come back looking good, I think that is a good direction, since the entirely active implementation is a clean, easy thing to build, compared to a system having both an active and passive crossover.
Now, regarding woofers. This is an interesting topic. My thinking is that I need to do some simulation on basic crossover points and driver sizes to see what works best, but I am thinking that if we work our way from the top, with a 26mm tweeter, the biggest mid you would want to use for really smooth off axis is probably around 120mm (or less). Now, going from the mid down to the woofer, you don't want to get into a situation where you have a huge woofer with big xmax and resonances all over the midrange, since you're using it up relatively high (say we want drama free bandwidth to 500hz or above.) This doesn't invalidate the use of a subwoofer, but it's something we need to look into.
Okay, challenge accepted The problem won't be coming up with ideas, it'll be limiting it down to a couple serious suggestions.I think for the sake of fun, we should be looking at a budget of $160 per speaker. I think this is the sweet spot.
Some data. I simulated most woofers and subs in the 8-10" size range from about 50-$120, also including some 7" models such as the Anarchy 708 and Dayton Esoteric 180ti. I graphed their maximum SPL/Frequency when put in a closed box of optimum size. I think selected a sort of median driver, and turned off everything that had less bass output (SPL at 40hz) than that, leaving 12 drivers. The ones which made the cut are somewhat interesting.
