Amplifier comparison: March Audio P452 (Purifi 1ET400A) vs Buckeye Hypex NC502MP vs AIYIMA A07 (TPA3255) vs Onkyo TX-NR737 (125W Class AB)
f1shb0n3
I'll use this thread as my personal blog in The Quest to find The Answer to The Question about Amplifiers. My subjective one, informed by the best science known to me. Both the question and the answer are to be figured out, my first revision of the question is: "What are the audible differences between different power amplifiers?"
I have a few amps laying around and using my near-field to mid-field desk setup of KEF R3, I'm equipped with all gadgets and cables to make a proper comparison of amplifiers using my own ears.
Disclaimer: I'm not an electrical engineer, not even an experienced audio enthusiast. I'm doing this test for my own understanding and education and to compare the gear I have at hand. I'm also not picking favorites here - each of these amps work great for its intended purpose and is a part of an audio system in my home.
Products involved
  • March Audio P452 Class D amplifier using Purifi 1ET400A chip with Alan's custom input buffer. Amir's review of a comparable model by Nord, I expect P452 to measure not too far from it.
Nord Three SE 1ET400A Dual Mono Stereo Amp With  Sonic Imagery 990Enh Audio Measurements.png
Nord Three SE 1ET400A Dual Mono Stereo Amp With  Sonic Imagery 990Enh Power into 8 Ohm Audio M...png
Nord Three SE 1ET400A Dual Mono Stereo Amp With  Sonic Imagery 990Enh Frequency Response Audio...png
Buckeye 6ch Nc502mp Measurements Frequency Response multichannel amplifier.png
AIYIMA A07 TPA3255 Measurements 32v 5 amp power supply Frequency Response.png
  • Onkyo TX-NR737 AVR with 125W Class AB amplifiers. No measurements are available to my knowledge, looking for comparable ones for reference.
Diagram of the setup
Status so far
Volume matching is a serious challenge, still working to confirm I'm within 0.1dB.
Heard distinct differences between Purifi and Hypex and between Purifi and Onkyo AVR so far with my best attempts in volume matching.
Details on specifics comparisons and exact settings will follow.
Updates from the thread below
maty
Tarragona (Spain)
Please, with very good recordings, DR > 11.
And acoustic and / or electric instruments. You know, jazz, folk, orchestral...
With today's recordings of popular music all computer manipulated the audible differences should be much smaller, I say.
restorer-john
So you have your speakers on a chinese restaurant lazy susan? Awesome. I've got one I use for heavy amplifier repairs on my lab bench.
I applaud your efforts, but attempting to compare amplifiers with that dodgy switcher (pressing both switches at the same instant for both channels) is doomed to failure.
You need to electrically balance the levels. Why even bother with the mini-dsp at all for comparison purposes- it will be a bottleneck you don't need?
F
f1shb0n3
Allows for faster comparison between speakers in the exact same position, audio memory being short and all. Works out well, only had to use replace with heavy duty rotation hardware. Eventually motorized and remote controlled will be perfect :)
Indeed when switching two switches simultaneously I get short breaks in both channels that were a bit confusing in the beginning, but was easy to learn to ignore. I'd appreciate suggestions for a better switch - at Amazon many had same ground connected to all black terminals and could not find a single-button one that would switch 2 channels simultaneously without common ground.
I tried measuring voltage at amplifier with 1kHz square wave for Purifi and Hypex and found that it's not representative of the perceived volume. Couldn't differences in output impedance between amplifiers affect perceived volume at same voltage? Still unsure of the "proper way" to volume match when comparing amplifiers.
MiniDSP SHD is great tool for volume matching in my use case - with 2 DAC outputs, separately digitally attenuate-able in 0.1dB increments. PEQ can be applied separately to each too which will be very useful to try to compensate for the 0.5dB dip at 12-20kHz in the frequency response linearity of Hypex when comparing vs Purifi. I think this one might be audible and curious if it's "correctable".
I also use it for Dirac Live room correction - it improves my listening experience in with all speakers in all settings. When comparing amplifiers will be doing it with and without Dirac enabled. I'll eventually integrate a pair of stereo subs with the MiniDSP, after I'm done with all fun comparisons I plan to do.
restorer-john
Use a sine wave at 100Hz with your DMM. (assuming you are using a DMM and many are only accurate with sines at low frequencies)
raindance
125 watt class A amplifiers - what, does the Onkyo weigh 100lbs?
abdo123
Brussels, Belgium
F
f1shb0n3
I want one, happy to be needing it :) Can you recommend a reasonable more expensive one from Amazon? I’m confused when I see the variety of different models with features I don’t understand if I’ll ever need..
tomtoo
Germany
Why it should be accurate for just comparing? It will give a wrong number, but if both voltages the same it will give the same wrong number for both. Or do you see this different?
restorer-john
He was advocating using a square wave at 1kHz.
abdo123
Brussels, Belgium
The one i linked is fairly good for its price and should be more than good enough for this purpose (or anything really in the audible band). it's also small and portable.
tomtoo
Germany
Thats not what i would do. But i not see how it would change the situation. He is not looking for the absolute number, just if both voltages are the same.
Its like having a ruler thats wrong made and shows instead 1m 1.20m.
Useless for a absolute number but perfectly usable to see if two objects have the same size.
amper42
When I compared the Buckeye NC502MP to the March Audio P452 I used REW pink noise to level match both to 75dB. What I found was the P452 was 1 db louder than the NC502MP. Setting the RME ADI-2 DAC volume to -33.5 with the P452 and -32.5 with the NC502MP matched levels at 75dB.
If your P452 gain is not built with a 26.5dB gain stage but instead with the later offered 20.5dB gain then the settings for level matching will obviously be different.
boXem
Europe
The square wave is a sum of sines. So the frequency response of the amplifier will have an effect on the voltage read by the DMM.
1 kHz sine via oscilloscope or 100 Hz sine via DMM are more reliable.
PierreV
A bit of lateral thinking might help here
If you pass a blind test between amplifiers, there will be an endless debate about the proper level matching techniques you did not use or executed poorly that will never be settled.
I would suggest matching levels by ear until you reliably fail the blind test.
Blumlein 88
Could be his meter is reacting slightly to the switching frequencies of those class D amps. Might need a simple filter on the meter.
Oops didn't notice the square wave part. Yeah use a sine wave.
tomtoo
Germany
Yes the FR of the amp will also have a impact on overall loudness.
But this was not my point.
My point was its not importend to use a highly accurate rms meter. As long you just compare two levels. It will show shit, but the same shit if the input level is the same.
F
f1shb0n3
Related question for the electrical engineers here - could different amps measuring same voltage on a competent meter/oscilloscope with 1kHz or 100Hz sine wave, produce different volume due to their output impedance differences or some other factor?
boXem
Europe
If the matching is done with speakers plugged (it should), no difference at the matching frequency. But since the output impedance is fequency dependant, it could happen at different frequencies.
