Sorry not possible as OLED and RCA connectors are connected to our casing .
Okay. Understood. A bit disappointed; packaging has kept me from buying the best offering from Audiophonics tested here, Orchard's best as only offered presently, and similarly your Revolution before this. Disappointed that will likely remain the same here.
To possibly sway me, what exactly can be / will be displayed on it? Assume that I am running RoPieee on it, not the bare RoonBridge, and/or Moode, Volumio or other.
Please note... in the following case style I will run a DigiOne, Boss v1, and/or ApplePi (you discontinued the Katana before I had need for that; once the time came for that tho, I could not longer buy it. But I'd own the Katana too if not for that). Shown is hands down my favorite streamer case. And all I want to use when the RPi + DAC HAT is not tucked away in an equipment room or behind an equipment rack.
I would like to give the Boss v1 to a friend and replace it with the Boss v2. But the packaging doesn't lend itself to using this case. Please consider producing another version of the Boss V2 DAC HAT in the traditional form factor of the Boss and Boss v1.2. Thank you.
RoPieee displaying what I am streaming to if from Roon:
(note the 2nd display that is off in the picture, partially obscured behind the one that is operating. That one has the DigiOne mounted.)
Shown swapping to a Boss or Apple Pi:
(The cockeyed heatsink on the Pi3 is because of the battery (?) on the bottom of the ApplePi, calling for use of taller standoffs. But I can get by with the shorter standoffs if I do this with the heatsink.)
