Hello everyone, I have a question about the A80. I'm running the A80 with a sampling rate of 96kHz and 24-bit under Windows. That should be sufficient! The A80 plays everything without any errors. With 192kHz, I occasionally get errors in the A80 device. It automatically sets itself to approximately 352.8 kHz! I don't know why. It seems to be a bug. Then the frequency doesn't synchronize with Windows, and a "strange sound" appears. And mostly in the YouTube output with some songs that are older (10 years old) or poorly recorded. I've been told I don't need the ASIO drivers, since Windows also has the High Audio 2.0 driver, which I can confirm.
Now to my question. The A80 is connected via USB-A 3.0 to the A80 via USB-C. I can set the A80 to a maximum of 192kHz, but anything above that (384kHz, etc.) gives me a "Device" error, which, for example, means the application can no longer access the "Audio Device." I then did some research and found something that says the maximum frequency can be set to 24-bit 192kHz, which should work in Windows.
Is that true? From what I've read, higher frequencies only work with Foolbar 2000 or the software, which I don't need and won't install. Did I understand that correctly, or is the problem elsewhere?
