This might be a nice one as well: https://www.lautsprechershop.de/hifi/startairkit_en.htm
There are several cabinet iterations of this design which has a low crossover count: Duane Brown Dayton 4.
You mean going the "single full range" way? or some line array?Cheap? Yes
Easy? Yes (broadband element)
Easy to get really good? It is a really good driver in any case then they should go into a sensible construction.
Taking into account the high technical performance and very low cost, TC9FD18-08, in my opinion, is just incredible speaker!
Peerless TC9FD18-08 | HiFiCompass
The THD measurements at voltage level 2.83 Volt were carried out with High Pass Filter "on" (2nd order Butterworth type, 80 Hz cutoff, HPF2-80) The THD measurements at voltage level 4 - 11.2 Volt were carried out with High Pass Filter "on" (2nd order Butterworth type, 150 Hz cutoff, HPF2-150)...hificompass.com
Search the DIY forum, it is a favorite speaker element among many. Popular also in line speakers, see # 1358
Wilson Audio TuneTot Review (high-end bookshelf speaker)
That's a great Freudian slip. It provided a little comic relief in what is otherwise an overly comical thread. It is not a Freudian slip, just a language slip. I edited it. English is not my native language.audiosciencereview.com
Order when they get them again. They are popular.
Home
Peerless by Tymphany TC9FD18-08 3-1/2" Full Range Paper Cone WooferThe TC/TG Series offers a high performance full range and mid-bass solution for TV products and other compact applications. The use of leading-edge technologies like a polymer chassis, NRSC (Tymphany patent) paper cone, and a...www.parts-express.com
Both, but one driver keep in mind that it has low sensitivity.Not so much power, does not go so deep in frequency but wow that price, for that performance.You mean going the "single full range" way? or some line array?
Of 4" cheap 2-ways, the Dayton4 are really hard to beat in sound and performance.
As long as you can measure to verify correct and ensure consistent performance, would consider Bagby Helix MT.
From Parts Express, the DA-Wave looks like a nice step up from the C-Note.
If you do not have adequate measurement equipment, have to agree that you may be better off purchasing.
It is quite cheap, and subjective opinions are very positive! Too bad there is no full data for it (I dare to say "no data" at all).
I posted in PETT regarding the correct locations for the tweeter and woofer within the baffle and maybe some measurements.
Anyways... the woofer on the Dayton 4 is the same is in this speaker?:
Dayton MK402X Review (Bookshelf Speaker)
This is a review and detailed measurements of the ultra-budget Dayton MK402X bookshelf speaker. It was kindly sent to me by a member and costs US $70 a pair plus $8 shipping on Amazon. Note that this is the revised version of MK402 (hence the letter "X" after its model number). From the...www.audiosciencereview.com
I dream with a DIY community driven - Klippel NFS data backed - waveguide loaded - SVS Prime Satellite killer!
I have MiniDSP UMIK and "ghetto" DATS equivalent, and know how to make basics measurements but not to the point of designing a passive crossover.
Anyway, why do you recommend measurement equipment for a DIY speaker?
I'm not affiliated with him, but:It is quite cheap, ...
I know you have built several speaker and subs and obviously like DIY. I am still writing this reply the way I am in case other folks thinking about DIY are following the convo.Hi!
Looking for a cheap and good DIY speaker design. I don't care if it's available as kit or not.
The idea is builidng 5 of the same and pair them with one subwoofer for one "el cheapo" 5.1 home theater setup (the receiver is an old ONKYO 313).
Some EQ will be available thru EQ APO, as I will be using a PC as source.
My first alternatives are Overnight Sensations MT and the C-Note, but I would like to hear your suggestions and hopefully have same DATA (I know the C-Note was reviewed here).
Also, it would be great if they are sealed to avoid port resonances and be able to mount them very close to the wall, but no problem if it's ported.
Cheers
