Is there any link to all those measurements?If you're interested in specific measurements, feel free to tell me.
They don't exist yet.Is there any link to all those measurements?
Please do measure power x THD+N into 32 ohms of all 5? Tks a lot.They don't exist yet.
If you're interested in something specific (Jitter of x, Noise of y, THD+N vs Power of z), then feel free to tell me and I'll measure and post the results.
The only place where I could still find the Ugreen is here: https://www.ebay.com/itm/255096654642Can you send me the link on Aliexpress for the ugreen with 43131? I can only find the KT0210 ones.
Has anyone measured CS43131 in this form factor? I'd love to go back to the Apple Dongle dimensions, but my memory of the 31993 EM noise is still fresh.
cat /proc/asound/card1/stream0
TTGK Company Type-C HiFi Audio Adapter at usb-0000:00:14.0-4, high speed : USB Audio
Playback:
Status: Stop
Interface 2
Altset 1
Format: S16_LE
Channels: 2
Endpoint: 0x03 (3 OUT) (ASYNC)
Rates: 44100, 48000, 88200, 96000, 176400, 192000, 352800, 384000
Data packet interval: 125 us
Bits: 16
Channel map: FL FR
Sync Endpoint: 0x84 (4 IN)
Sync EP Interface: 2
Sync EP Altset: 1
Implicit Feedback Mode: No
Interface 2
Altset 2
Format: S24_3LE
Channels: 2
Bits: 24
Channel map: FL FR
Sync EP Altset: 2
Interface 2
Altset 3
Format: S32_LE
Channels: 2
Bits: 32
Channel map: FL FR
Sync EP Altset: 3
Interface 2
Altset 4
Format: SPECIAL
Channels: 2
Bits: 32
DSD raw: DOP=0, bitrev=0
Channel map: FL FR
Sync EP Altset: 4
cat /proc/asound/card1/usbmixer
USB Mixer: usb_id=0x262a0001, ctrlif=1, ctlerr=0
Card: TTGK Company Type-C HiFi Audio Adapter at usb-0000:00:14.0-4, high speed
Unit: 1
Control: name="Clock Source 1 Validity", index=0
Info: id=1, control=2, cmask=0x0, channels=1, type="BOOLEAN"
Volume: min=0, max=1, dBmin=0, dBmax=0
Unit: 10
Control: name="PCM Playback Volume", index=0
Info: id=10, control=2, cmask=0x3, channels=2, type="S16"
Volume: min=-16128, max=0, dBmin=-6300, dBmax=0
Unit: 10
Control: name="PCM Playback Switch", index=0
Info: id=10, control=1, cmask=0x0, channels=1, type="INV_BOOLEAN"
... and what is this ???![]()
Can you tell me does it support microphone?I just got a JCALLY JM30 dongle with the CS43131. I could not be happier. This plays so well with my phone that I have no desire for a DAP. I had a $700 DAP with AK chips and while I can not compare directly I feel that the JM30 is a better listen. The JM30 impresses me more than the DAP ever did.
Sorry, no idea.Can you tell me does it support microphone?
Just ordered a Jcally JM20 as a backup for my loved Ugreen HiFi Pro, I'm curious about the above information, is it taken from JM20 or other "no-name" CS431131 dongle? Or can anyone using the JM20 on Linux post the result of the command?Interface 2 Altset 4 Format: SPECIAL Channels: 2 Endpoint: 0x03 (3 OUT) (ASYNC) Rates: 44100, 48000, 88200, 96000, 176400, 192000, 352800, 384000 Data packet interval: 125 us Bits: 32 DSD raw: DOP=0, bitrev=0 Channel map: FL FR Sync Endpoint: 0x84 (4 IN) Sync EP Interface: 2 Sync EP Altset: 4 Implicit Feedback Mode: No
Not really surprising since the Ugreen has the same architecture of Meizu Pro with OPA1622 after CS43141 to give some more current in low ohm load.Meizu Pro is the best but unobtanium. The next best is the ugreen, surprisingly for me.
Unless you can hear hiss out of your cs43131-based DAC, the issue is purely academic.From what I could understand, in between other things, it tricks the dynamic range so that it appears to be better than actually is or something like that. Most important I think is if these issues are purely academic or have any consequences to the user.
I guess, CS43131 may show lower THD+N if the test time is shorter. Hotter chip = less current. Anyway, I consider that chip as an optimally engineered portable DAC, whatever fake dynamic range and 96k only(low current draw, cheap, headphones amp is integrated) - nobody complains about its sound quality, including meHere you go:
