A Thread Dedicated to Cirrus Logic CS43131
Ah there's a web app that can access the dongle? Does that work on the computer as well? Tough I did forget what tempmail I used so I can't log in with that anymore :D
It works with any Chromium-based browser: Chrome or Edge for example. The webapp relies on USB HID or Serial APIs that are only exposed in these browsers.
TRN Black Pearl is great is much better not like my Jcally M20 Max who make hot and can confirm work with walkplay app and u can change DACS to class AB or H, Low or High gain make screenshot is great DAC so happy and many filters and EQ for 26£ 7days delivery take to Linsoul to delivered to me View attachment 447801View attachment 447802View attachment 447803
How did you enable the gain and other functions in walkplay app. I can access only the equaliser. This is what I got:
Do you have the latest version of the apk?
I think earlier versions of WalkPlay would not show these features even if the dongle has them enabled.
Yes, I tried to update it, but it says it's up to date. Downloaded yesterday.
U need latest version and U can change inside all version 2.2.1
Made this short only most best is normal all
How to get that version 2.2.1?
Current version on szwalkplay is 2.1.3.
jusr press Mine then show you the version on bottom ( App Version) and be updated
Hm. When I log into browser version and try to do/change something a popup says the devise is not supported.
When I enter the app, there is massage that it is the latest version and I do not need to update.
When I enter the profile, it states the version, but I cannot do nothing from there.
Snowsky Retro Nano. I have been using it for almost a year and I have to say it is excelent device, I use it in work and listen music and take calls with ti all day. Internal battery is little bit a problem. With Sennheiser IE600 battery lasts 8.5hours, so when I drive home battery usually cuts out. So with lathe I made plastic battery analog and soldered 20-year old camera battery on to it with strong double sided tape; boom! one week of music without draining phone battery too much.
New SMSL AL400 amp has the same DAC, no DRE settting though
can anyone upload the list of walkplay supported devices as the link is not available anymore? thanks!
