This is a review, listening tests, and detailed measurements of the 64 Audio tia Trió IEM. It was kindly drop shipped to me and costs US $2,299.
I was not a fan of included cord. It feels sticky even though it isn't. And is rather thick and has memory. Here are the included pads:
I always use the middle size silicon tips for measurements which worked out great in this case. The seal was excellent and gave proper results on first try.
This is a 3-driver design with passive crossover.
Note: The measurements you are about to see are made using a standardized Gras 45C. Headphone measurements by definition are approximate and variable so don't be surprised if other measurements even if performed with the same fixtures as mine, differ in end results. Protocols vary such as headband pressure and averaging (which I don't do). As you will see, I confirm the approximate accuracy of the measurements using Equalization and listening tests. Ultimately headphone measurements are less exact than speakers mostly in bass and above a few kilohertz so keep that in mind as you read these tests. If you think you have an exact idea of a headphone performance, you are likely wrong!
64 Audio tia Trió Measurements
As usual, we start with our frequency response measurement:
I was very naturally pleased to see the excellent bass response and compliance with our target up to about 2.5 kHz. Past that we see a droop and some irregularities. I don't usually put much value beyond 10 kHz but seems like we have a boost there.
Compared to our target, we get the following deviation which is not bad:
What is bad (objective) is quite high distortion in treble region:
Fortunately the amount of energy in music is quite low there so you can rely on 94 dBSPL results which is reasonable.
Group delay is not very revealing with IEMs and such is the case here:
Impedance is very low and variable:
Fortunately this is a very sensitive IEM so just about any device should be able to drive it:
64 Audio tia Trió IEM Listening Tests
As noted in the intro, I started with the largest silicon tips and was quite taken back by how bright the sound was! The bass that showed up in measurements were nowhere to be found. That is when I noticed there was no isolation of outside noise (the faint fan noise from my PC was just as evident). I put some pressure on the drivers and that gave me some bass but not enough. And certainly not consistently so. The rubber tips seem to be bigger so I tried the largest one there. That got me half-way there. I got the rest by shoving them all the way inside my ear canal to the point where I could feel them against my inner ear -- a sensation I did not like. But for testing, I tolerated it. Now there was good bass response and the brightness was all but gone. It was replaced however with rather dull highs. So I started to EQ to correct the highs:
This opened up the highs nicely including some air and separation in instruments. Even though my hearing sensitivity is not great in the last octave, I could hear the improvement in the sharp notch filter at 14 kHz so left it there.
With all these fixes, the sound was good.
I was yet again pleased that 64 audio pays attention to bass response as I had noticed in my review of their U12t IEM. While objectively this response was there, as I explained subjectively, it was totally absent for me. Whether you fall in the same bucket as me, is hard to say. If you do, you are going to have a pretty lousy experience. If you can use the other tips to get the bass back, you still need EQ because the highs will now become deficient without it. With the combination of proper tips and EQ, you get good sound, as is the case with many headphones and IEMs.
Level of distortion is disappointing in such an expensive piece of audio equipment. While this seems endemic in balanced armature drivers, I have tested others at a fraction of price with less of it.
Because I can't get good sound out of these IEMs in my listening tests, I can't recommend the 64 Audio tia Trió. It pains me to say this as the company is just a few hours from me! Hopefully the work on improving their compliance to research targets. And figure out why the fit is not as broad as it should be.
