CamRector
- Joined
- Sep 1, 2022
- Messages
- 81
- Likes
- 80
40000What is the total capacity of the capacitors?
What's the reason/decision to use the additional capacitors - I ordered 2 boards for additional capacitor but didn't install them!40000
Bus pumping yes and it was a simple solution to connecting 2 amps to 1 power supply.What's the reason/decision to use the additional capacitors - I ordered 2 boards for additional capacitor but didn't install them!
I read this can help with bus pumping but also understood this wasn't a topic with these SMPS and these 3e boards (required when the amplifier operates in half bridge).
Going through 3e audio's website, their link to buy goes to their Aliexpress page. Seems like as long as you're using their store, it's from the manufacturer. But you'd still recommend audiophonics over the manufacturer?280€ is the high price because I go through Audiophonics, you can save 20% through Aliexpress but I wouldn't take the risk)
That being said, at €280 you have a nice amp which should last over time with a Sinad which would place it in the top 5 ASR
I'm also in the US so I'm a bit concerned about the shipping, but if the only way to have a warranty is through a reseller I think that's probably worth the extra money.
I’m in the US and did Ali. No issues at all.Going through 3e audio's website, their link to buy goes to their Aliexpress page. Seems like as long as you're using their store, it's from the manufacturer. But you'd still recommend audiophonics over the manufacturer?
To clarify, I guess what I'm asking is what is the risk you were mentioning about buying from Ali?I bought my 3E Audio stereo modules from Audiophonics and my Mono from Ali )
Both are reliable. But as far as I know no more stock for the moment.....
I also couldn't find anything on 3E's website about a warranty, but that's not to say there isn't a manufacturer's warranty.
I'm also aware they're currently out of stock.
For those in the EU having a local reseller responsible for warranty makes some sense. I'm not sure it makes much difference for those elsewhere in the world.Going through 3e audio's website, their link to buy goes to their Aliexpress page. Seems like as long as you're using their store, it's from the manufacturer. But you'd still recommend audiophonics over the manufacturer?
I've bought quite a bit of stuff from aliexpress with no issues. Larger items take a while to ship (2 weeks) smaller take less. My 3Es have not failed yet.To clarify, I guess what I'm asking is what is the risk you were mentioning about buying from Ali?
I’ve had several issues with ALIEXPRESS purchases - damaged products, misleading listings, items stolen from packages- and despite talking a very big game about free returns, refunds, etc. ALIEXPRESS is useless when it comes to supporting me as a buyer and getting a refund for me. They have always take the seller‘s side in a dispute and run me through a gauntlet.
Caveat emptor.
Daniboun,This is why I am using Paypal ) Never got any issues and easy to get refunds
I also had made over hundred transactions in Aliexpress and never had any problems to get refund.I‘ve done dozens of Aliexpress transactions over the past 10 years but just want people to know that when things go wrong, Aliexpress do a very poor job of backing up the customer.
There is a small pcb with a small heatsink and 4 caps,....above the psu module and right of the 3e module.View attachment 311735
Hi amigos,
I'm finally done. I made some last minute changes, using some Japanese shielded cables I had in stock for the speaker connectors. I also had to opt for smaller binding posts given the size of the enclosure. I share again the list of components below.
For those just starting out; patience will be required) It is not always easy to drill the enclosure without suitable equipment... so bring the right tools)
Here is an amplifier which will stand up to The Topping PA5/RA3 with a budget which remains controlled and displays a good Sinad of 105DB (THD+N in 4Ω / F = 1kHz, Po =5W = 0.0007%). As for its reliability, I think taking into account the feedback, we should not be worried. )
Enclosure : Click here
3E Audio Module : Click here
PSU (set@42V/6A) : Click here
Neutrik XLR (Panel Mount) : Click here
Binding Post : Click here
Power Switch : Click here
220V LED : Click here
Optional (AC filter) : Click here
What is that piece and is it in your parts list?
Trying to replicate your build![]()
