"Bamboo V2" project. 3E Audio 260-2-29A Stéréo Rev. B (OPA1656) + PFC/LLC PSU. APx555 Measurements )
Do you think it's possible this project (or similar with the 3E board) could fit in a 1U rack chassis?
I just got mine and still deciding on a PSU, etc.
Also was curious about something as a noob, since I see 12v triggers and soft start power supplies pretty commonly…
I know speakers popping is bad, which is why I use a power sequencer, but would there be an issue with leaving the amp switched on but pulling power?
The 3E module size is 105mm x 90mm x 38.5mm. You have to consider a case with a height of at least 5cm in my opinion....
Regarding the trigger function it is relative to the PSU that you will choose )
You dont have to worry about pop noise issue with this module. It is really well protected.
Do you have distortion measurement against frequency in Amir style? The multitone distortion is very good on high frequency.
I did not measure it but should be the same as the Rev A measured by Amir.(@+- 5 % )
The Connex module has two high-frequency snubbers to filter the high-frequency noise which can explain the good multitone result.
Thanks for the reply!
So... not that I would actually consider doing this, but just curious... do you think replacing (or in some way moving/angling) the caps would be a terrible idea (in an attempt to fit it into a 1U chassis)?
And sorry, my post might not have been all that clear, but I'm not at all worried about my speakers popping, just didn't know if maybe an amp/PSU would need to be powered off using a switch instead of just unplugging it from power (like maybe it also needs a "soft stop"?). Is there a PSU you'd recommend if this is the case? It will be ideally plugged into a power sequencer.
@Hall of Canons replace the 4pcs BUCK cap to something like 25mm height like 1200uF as below one should fit into 1U chassis, you can just power on off the power supply feed to the amp, this is the simple way.
here https://www.mouser.com/ProductDetail/Rubycon/63ZLH1200MEFC18X25/?qs=T3oQrply3y%2BXT41AV6EKyA==
The best practice is to use a Power On/Off switch ) Get the same PSU as mine if you need a soft start operation (page 1)
Hello,
first I'd like to thank you @daniboun for introducing me and my services regarding high performance audio measurements
If somebody is located in europe (EU) my measurement service might be useful
I offer 3 stages:
1) DIY: via remote https://www.akulap.de/joomla/index.php/en/en-shop/product/view/15/255
2) I perform the measurements: https://www.akulap.de/joomla/index.php/en/en-shop/product/view/15/166
3) Full custom measurements. For very advanced setups
Of course all measurment results are confidential.
docjordan
Hello,
I offer 3 stages:
docjordan
Hi,
Thanks for these useful services.
However you should declare yourself to the ASR's staf (@AdamG & @BDWoody) as a company. ;)
Yes, you are right, I'm quite new to this forum but not to audio ;-)
Yes, I am a (small) 100% independant company, and I offer services (mostly related to audio measurements but my key knowledge is software development and DSP).
Hello,
Hi doc )
Nice to read you and welcome on board :)
Sorry, I’m not sure why I’m having so much trouble communicating this, but I’ll have it in a rack plugged into a power sequencer, because I don’t want to use a switch for each thing I need to power on and off in my setup. I already have the power sequencer (and conditioner, technically) and I’ve been using it for my recording studio, and I’m adding this amp with a second set of speakers to the system.
(The speakers I have been using previously have built-in amps.) The question is what PSU should I get for this purpose so that disconnecting power (or for that matter, reconnecting power with the amp “on”) doesn’t harm anything?
(Just imagine for all intents and purposes, it’s plugged into a power strip and I’ll be turning on/off the power strip, not pressing a switch on the amp itself, or imagine there’s no switch on the amp itself, if that’s possible)
OR would it be harmful regardless and I’ll need to figure out a way to add a trigger or something?
In this case, I advise you to opt for a PSU with a Soft Start, this will allow you to delay the increase in current and ensure protection for your amp. It remains optional but the PSU that I proposed here seems appropriate to me)
@daniboun
Hi,
I bought the revision B of the 3E Audio 260-2-29A module and I am now lost about the power supply you suggest for this project :)
Can you help and declare what is a good power supply for this 3E Audio?
I see you mentioned:
- Micro-audio and now we have second revision available ( SMPS600-R2)
- MORNSUN LOF550-20B36
- Yongzhuxing 600W PFC /LLC @48V
- Connex ( not sure about the model)
- some others ???
Second question, in which of the mentioned we have SoftStart and is it really a required feature?
thank you
Andrew
Hi,
Get the Yongzhuxing 600W PFC /LLC @48V or the Mornsun, both are safe value.
The Yongzhuxing has the best performance / price value.
The Soft Start module is helpful for the Extra caps module (this helps to avoid the rapid rise in current)
@daniboun
Thank you for your reply :)
Yongzhuxing is 48V but MORNSUN LOF550-20B36 is 36V only.
Any consideration about the output voltage ?
Can you share link to the shop where you bough Yongzhuxing, please ?
@daniboun
The Mornsun can be found @51V as well. See ASR review )
Link to mine is @ page 1 )))
Ah, so this is a webshop, I thought this is an info page. My Chinese is no so good, but found it on Aliexpress too.
If I go for Mornsun, should I select the one with higher voltage, as we have a range 36-51VDC for 3e audio?
What is the recommendation for voltage input ?
Max voltage is 51VDC ) Get any from 48 to 51V
Привет,
Приобретите Yongzhuxing 600W PFC /LLC @48V или Mornsun, оба варианта имеют безопасную стоимость.
Yongzhuxing имеет лучшее соотношение цены и качества.
Модуль плавного пуска полезен для модуля дополнительных конденсаторов (это помогает избежать быстрого роста тока)
Здравствуйте! Сегодня я получил свой Yongzhuxing 600W PFC /LLC @48V, его индуктор и трансформатор издают звук! Были ли посторонние звуки в вашем? Могут ли эти звуки повлиять на качество звука усилителя?
