Make sure you aren't recording to the SD car as the same time. The f6 can be used as audio interface up to 96 kHz, but you are limited to 48kHz if you record to an sd card at the same time.
As an aside, i think several people that have responded to this thread don't fully understand what field recorders like this are actually used for. Yes they can be used as an audio interface, but that's more of fluff a feature to appease those who don't really know what they want or need.
Videography and the associated disciplines are just a hobby to me, but I am pretty well versed in them. Imo, if you are looking at a field recorder from the Zoom F line or Sound Devices MixPre line then the following things are far more important to you than how it functions as a ADC.
- Does it have timecode support, what type of timecode features does it have, and how accurate is the internal clock.
- How many inputs does it have and how many of them support phantom power. 48v only or 24v and 48v support.
- What are its power options. If it's an internal only devise, what type of battery or batteries does it use. Does it support external power, if so what type of connector does it use. If it supports external power, does it fall back to internal power cleanly so you can hot swap external supplies.
- What bit depths and frequencies does it support.
- what does it use for storage, and what storage related features doe it have. For example recording redundancy is a big deal.
- what type of meta data support does it have, and what other special features like pre-role etc does it have.
The hype from Zoom, SD, and other people in the industry about 32 bit, is about not needing to set and constantly monitor gain. Thats a huge load off the sound guys shoulder. A lot of small productions would happily trade audio quality for that feature. Also keep in mind The F and MixPre lines, are mid to high end consumer, lowend pro grade gear. Mid grade pro gear is going to be something like an SD 833/888, or Zaxcom Nomad. High end gear is probably going to involve a cart.
Edit:
Here is a review by a popular industry reviewer. He reviews a lot of prosumer grade gear.
