Worst measuring loudspeaker?
Palladium
You have to credit it with consistently terrible measurements no matter where you start: cabinet vibration, frequency response, step response and waterfall, all vying for the worst I've seen on Stereophile. Efficient though.
but_you_never_heard_it_yourself.txt
fpitas
Northern Virginia, USA
8000€ pair price passive full range loudspeaker with following measurements:
Source: https://www.hifitest.de/test/lautsprecher-stereo/cube-audio-jazzon-21959
The full range crowd don't seem to care about the FR. Only occasionally do I see someone commenting on the ear-piercing shrieks at some frequencies.
fpitas
Wow,
£6500 plus stands
Why do they hate 6.5kHz?
Dialectic
a fortified compound
I nominate the Escalante Design Fremont. Now long out of production, MSRP was $19K/pair in 2008:
These terrible measurements did not prevent this rapturous subjective review:
A quick Google search confirmed that there were still users/fans of these loudspeakers as recently as 2020...
fpitas
You pay for convenience. Notching out the 4kHz saves the owner the trouble of notching it themselves.
lashto
many thanks, I was actually looking at those Nenuphars.
According to the manufacturer, the (latest) drivers actually measure quite well (for a full range). Looks like they did not think much about the cabinets.
With proper enclosures, the 10kHz area can be easily tamed with EQ/DSP and distortion looks reasonable too. But still, such measurements and prices...
fpitas
I'll note those graphs are 1/4 octave resolution. But yes, with enough EQ you can probably tame them.
lashto
yeah I was looking at that, the manufacturer measurements are not exactly same. Vertical scale is also very different, hard to compare the graphs.
For €1000 I would try a pair, but they want €7000 for the only ones which measure ok-ish...
fpitas
For €1000 I would try a pair, but they want €7000 for the only ones which measures ok-ish...
It seems excessive.
lashto
It seems excessive.
you are very nice :)
They go with the story of years of research and low count sales. The website looks ok, provides tech params and some measurements and I can ~understand that story too.
But wtf did they 'research for many years' when those drivers/enclosures have sudden, 10dB FR spikes and a 20+dB swing between lowest & highest points ?! Looks like I should forget about those drivers too. Sooo hard to find a reasonable single driver...
fpitas
They go with the story of years of research and low count sales. The website looks ok, provides tech data and some measurements and I can ~understand that story too.
But wtf did they 'research for many years' when those drivers/enclosures have sudden 10dB FR spikes and a 20+dB swing between lowest & highest points ?! Looks like I should forget about those drivers too. Sooo hard to find a reasonable single driver...
Marketing people say a lot of things. Sometimes they aren't entirely truthful ;)
thewas
And also measured in listening room, not anechoic/gated.
Considering how well a 20$ Peerless 9TC measures that makes it even more ridiculous.
thewas
Most coaxials have a dip in the highs due to diffraction which is increased exactly on-axis due to the symmetry and mostly disappears though off-axis, current Genelec and KEF being rare exceptions.
lashto
talking about single drivers & horns, here's a good example for this thread. Comes from another bunch of full-range-driver 'geniuses': Voxativ
yours for only $30.000
fpitas
My 511s do something suimilar, probably for the same reason, although it's only a few dB at 2kHz.
fpitas
talking about single drivers & horns, here's a good example for this thread. Comes from another bunch of full-range-driver geniuses: Voxativ
The best I've seen is putting a full range in a properly done transmission line. Still a bit choppy.
thewas
I can beat that :p (and had the "pleasure" to listen to some of their models at audio shows)
lashto
Seems so but I do not want another 'box'.
I did listen to open baffles a few times and liked that "openess". My idea was to put a full-range-driver on an open baffle and then use the receiver's DSP to fix the FR issues and crossover the SB at 80Hz. Easy said.
In practice, I just can't find a pair of reasonably good full range drivers below $1000. (more would be too expensive for such an experiment). Also there seem to be very little data/measurements about the distortion of the full range drivers
fpitas
The extreme low frequency cone motion in an open baffle will give you a lot of intermod, too.
