WiiM Pro Streamer
Joffy1780
Joffy1780
€152 on Amazon.de currently. Superb value at that price!
kukocz
PL
It was one-day "deal" ;)
Joffy1780
15% off on US Amazon at the moment, not many left though!!
ClassicGuy
Anybody knows if I can control the volume via WiiM Pro control if I am using the optical input to optical output?
Achim1812
Düsseldorf, Germany
Good day from Germany,
I do not know why it is not longer possible for me to choose the ethernet connection. The software offers only wi-fi. Cable is fixed, Fritzbox is on and shows the LAN connection and till yesterday it worked without any issue. Any ideas?
Thx in advance, Achim
derek13
Does it allow you to disable WiFi in the Network Status menu item?
antcollinet
UK/Cheshire
Perhaps it is only a sensation, but I prefer the coax
It's only a sensation.
There is no difference between optical and coax as far as sound quality goes - except that optical has a better chance to break ground loops if they exist.
Achim1812
Düsseldorf, Germany
@derek13
No, there is no option. None in "network status" and none in "audio input".
Later: I contacted Wiim and are waiting for an answer.
JimmyMac
Chicago, IL
Hey gang, got a question about the led status light on the Pro. I like it set to "off", but on my newly acquired Pro it randomly turns back on, and then the "status light" switch doesn't work, and I can't turn it off. Only rebooting turns it off, but then the problem reoccurs once the unit is turned back on.
Anyone else have this issue? I can also send a ticket in to WiiM, but wanted to ask here first.
I have the latest firmware from April 6.
Thanks, JMac
derek13
@derek13
If it hadn't been working previously I would have thought it could be the firmware version: my early one didn't enable me to disable wifi and rely on the Ethernet connection but that was fixed by a firmware release a few releases ago. Have you tried factory reset and start afresh?
