artishard116
- Joined
- Sep 6, 2021
- Messages
- 26
- Likes
- 18
Thanks for the info. Already using a cable like you mention, so I can rule that out as the culprit.I also use optical input (sometimes). But at least in my case, auto-sensing works correctly. I have a TV connected to it, and it senses audio and outputs it correctly. There was a previous update that solved the only issue I had with optical: a delay between audio and video.
My unit maintains a rock solid connection. I use it mostly via Wi-Fi but I tried it hardwired for months and it works correclty. We all have different networking equipment so it may be time for you to isolate where the issue is.
I also used to have trouble with 12V trigger, but I realized the problem was an adapter I had that converted from 3.5mm plug to 2.5mm. I just replaced all that to a 3.5mm to 2.5mm cable and all problems gone. And yes, having some kind of customization for trigger auto off would be nice.
