Ralph_Cramden
- Joined
- Dec 6, 2020
- Messages
- 2,609
- Likes
- 3,527
Not for me, I already have too much remote
Yeah. I got the RX-A670 used for a good price, and did not check the specs closely enough. I think the very next model supports Qobuz, but not this one. Firmware update did not help.You sure?, see here
Yamaha MusicCast Products Can Now Stream Qobuz
Qobuz, the Paris-based high-resolution (hi-res) music streaming and download service that launched in the U.S.www.soundandvision.com
You sure?, see here
You need to send this to wiim. They are very responsive.Since last update, I'm having trouble with 21V trigger. When listening at low volume, my amp suddenly makes a weird noise and shuts itself off. I had to disconnect the cable and use without it. No problems since then.
Anyone on the same boat?
I still have to test at higher volumes.
My workaround was to run an optical cable from the WiiM pro to the Yamaha AVR. I was a little surprised, but got solid 24/192 with a 20’ cable. I just change the output of the WiiM between coax and spdif for different rooms. Not as elegant a solution, but it works.well, for any of my MusicCast units the starting page looks like this, with Qobuz:
It may be possible to change which possibilities are displayed in the settings. I have never bothered with those, although I only use 2-3 of these.
^^That looks like the Yamaha A/V Controller app. If you check this link, it looks like your AVR supports Musiccast, perhaps try downloading the app:Yeah. I got the RX-A670 used for a good price, and did not check the specs closely enough. I think the very next model supports Qobuz, but not this one. Firmware update did not help.
Meanwhile it is March and the Wiim Pro is still vaporware in Europe...From Twitter: “WiiM Pro is expected to be available in the Europe in early to mid-January, please be patient.”.
Are you sure? Amazon Italy shipped in one dayMeanwhile it is March and the Wiim Pro is still vaporware in Europe...
I got mine, Nordic Europe, in early February.Meanwhile it is March and the Wiim Pro is still vaporware in Europe...
6 units, still readily in stock for days now: https://www.amazon.de/dp/B0BJDY6D1WMeanwhile it is March and the Wiim Pro is still vaporware in Europe...
Yupp that much seems true, for now.The voice remote seems like vaporware in EU though
Ordered my remote from the US.Yupp that much seems true, for now.
Where are you? ordered mine on 1st, coming tomorrow in UK.Ordered my remote from the US.
It's due here on the 16th may.
Ordered on the 4th.Where are you? ordered mine on 1st, coming tomorrow in UK.
