I think nobody will add 12 db on a frequency compared to another eq band. I don't think a speaker is designed to cope with that. And in total you can have a delta of 24! That's not something I would know an application for.
But the numbers are quite helpfull. Lowering the volume from 95% with approximately 3% per db gain in the eq settings, or put the maximum gain to - 1.2 db and adjust the rest accordingly and crank up the connected amplifier volume when needed.
So, thank you very much for explaining this. Much appreciated. I like this thread!
you are on the wrong track...
if we consider this 95 is in "flat" eq mode which makes no sense ...
if the +12db was huge just for demonstration.. I invite you to observe for example the presets of wiim.. you will observe boosts up to 6-7db or even often in the bass etc... no more this 1db of precaution...
so it's an opportunity to observe to what level to lower, a little on a case-by-case basis..
how much a +1db at 2, at 3 at 4 at 5 at 6 at 7,
by adding the famous 1.5db.
afterwards, if it was systematically by lowering a level .. it will be without problems and will allow the drc to be disengaged (option which is not offered)!
I'm not concerned but could be of use to anyone who wants to use this eq mode as it is
