DeepSpace57
- Joined
- Jun 6, 2019
- Messages
- 313
- Likes
- 125
Ok, WIIM finally responded about DEEZER
We'd like to give you a bit background on our support of Deezer and current status. We (at LinkPlay) supported Deezer in our streaming platform starting from year 2017 and there're many existing users who are using this service daily. IMO, it's not appropriate to disable it suddenly in our product and platform considering the existing user base.
The current issue started from early this year and affected a small percentage of our Deezer's user. We have worked with our API provider trying to fix this issue with the new API. We have finished the integration however our partner needs do more traffic tests on their API. Thus, we missed our original delivery schedule. We'll do our best to deliver it earlier.
At WiiM, we valued our user experience as our highest priority in our every day work and felt the same pain with our affected users. Our apologies for the inconvenience caused. We also valued the transparency most and we'll definitely keep you posted when there's new update. Thank you!
Deezer connect is now on. I believe the easiest way to use Deezer for Wiim mini users would be Deezer connect.
Open Deezer app
Connect it to Wiim mini
Enjoy lossless audio.
This would also allow the users to enjoy a smooth operation and original app.
I am so curious about when Wiim will provide it.
