It sounds good, but I don’t listen at high level!How does it fare with the LS50, the LS50 being pretty power hungry?
Just got the hotfix firmware update and HDMI appears to be working great so far. Audio works on sleep/wake from HDMI source and I haven't been able to reproduce the garbled audio issue from two firmware versions back. Will keep testing but good news so far! Love my WiiM Amp and appreciate how responsive support is.Is anyone else seeing significant regressions in HDMI behavior since the firmware update rolled out yesterday? I'm using my WiiM Amp with an LG C9 and Nvidia Shield Pro (2019) with HDMI CEC and auto sense enabled. Since the update yesterday, whenever my TV goes to sleep upon resume the WiiM Amp will not output audio until I reboot the WiiM Amp itself.
Yes, they respond very quickly to the bugs that they introduce in firmware updates. Perhaps, they should try testing new firmware properly before releasing it.Love my WiiM Amp and appreciate how responsive support is.
Can you give an example please?Yes, they respond very quickly to the bugs that they introduce in firmware updates. Perhaps, they should try testing new firmware properly before releasing it.
Testing HDMI ARC "properly" seems pretty much impossible ...Perhaps, they should try testing new firmware properly before releasing it.
Easy. Just buy each employee a different Smart TV and WiiM Amp to take home, and have them report back in a few weeksTesting HDMI ARC "properly" seems pretty much impossible ...
Don’t forget to buy all the old TVs from second hand markets. They must test EVERYTHING!!!!Easy. Just buy each employee a different Smart TV and WiiM Amp to take home, and have them report back in a few weeks
And even if they bought two identical Samsung models, they’d behave differentlyEasy. Just buy each employee a different Smart TV and WiiM Amp to take home, and have them report back in a few weeks
Is the question referring to whether the subwoofer level changes with amp volume control? I think the answer is yes it does already, that the SW out is variable. There is a subwoofer level control in the app but that’s for fine tuning.Anyone found a way to get subwoofer level to integrate yet?
In case this statement was misleading, it’s because I like to fine tune the relative subwoofer level between music albums.Would be nice to have:
- Subwoofer gain up/down buttons on the remote control
Ah, I was under the impression the subwoofer volume could be fine at certain points, but then end up either too low or too high when adjusting regular volume dial. Is this not actually an issue now then? Maybe I'm confused and was reading a different thread where I saw that.Is the question referring to whether the subwoofer level changes with amp volume control? I think the answer is yes it does already, that the SW out is variable. There is a subwoofer level control in the app but that’s for fine tuning.
The original Fosi V3 had that issue, but it was fixed with a 2024 revision.Ah, I was under the impression the subwoofer volume could be fine at certain points, but then end up either too low or too high when adjusting regular volume dial. Is this not actually an issue now then? Maybe I'm confused and was reading a different thread where I saw that.
Think I confused it with the Sabaj a30a, was reading that thread through as well.The original Fosi V3 had that issue, but it was fixed with a 2024 revision.
On the WiiM Amp it would be news to me.
Maybe just your speakers? I'm using the klh model 3 and get zero distortion at high volume.I am beginning to be a little suspicious of these tests. I have given the wiim a go and I think it sounds terrible next to some devices that were reviewed with poorer results. I don't get how it can score so high in tests when in use it doesn't sound that great. It is a cool device especially at it price but it struggles to play full range without distortion with any of the speakers I own.
I tried it with 4 sets of speakers. sonab OA14 (I actually bought it for those speakers) ess amt 1b, ohm walsh 3.3000, and a set of polk lsi9. Those speakers other than the polks are pretty easy to drive. I'm really disappointed. great reviews all around and a tested higher than other equipment I have.Maybe just your speakers? I'm using the klh model 3 and get zero distortion at high volume.
https://ohmspeaker.com/legacy-products/3/ 8 ohm 50-125w those are mostly vintage speakers and look super hard to driveI tried it with 4 sets of speakers. sonab OA14 (I actually bought it for those speakers) ess amt 1b, ohm walsh 3.3000, and a set of polk lsi9. Those speakers other than the polks are pretty easy to drive. I'm really disappointed. great reviews all around and a tested higher than other equipment I have.
Walsh "3.3000" they have vintage cabinets but modern drivers. I used a super cheap avr with them when I first got them. They aren't hard to drive. Maybe I got a bad wiim unit. I really want it to work. Nothing else I can think of with hdmi arc and streaming at this price point.https://ohmspeaker.com/legacy-products/3/ 8 ohm 50-125w those are mostly vintage speakers and look super hard to drive
