I agree that wideband measurements are a useful
addition in properly characterizing an amplifier. We can see if there are potential harmful high levels of RF present etc.
The point of the FTC is to avoid misleading of customers and is most welcome.
John's constant complaints about THD+N measurements with 250kHz bandwidth is flawed and in fact misleading!
Let me illustrate with some examples:
Let's say a less tech savvy customer wants an amplifier that has a very low noise level for his high sensitivity tweeters operating in the 2-20kHz band. He takes a look at the noise number measured with 250kHz bandwidth.
Amplifier 1 has a noise level of 250uV and Amplifier 2 has a noise level of 1000uV.
Amplifier 1 must be better than amplifier 2 right?.... Wrong!
Here is a spectrum of the very very expensive class A amplifier in the 50.000 USD price range I had in for repair a year ago (name removed). A noise level of 250uV is very poor. It is measured only up to 20kHz, but is does not matter since the noise is declining above that. Perhaps the noise would be around 300uV if measured up to 250kHz.
The noise is in the audible range and while spikes of -100dBV @ 2kHz is not very much it will be audible on a sensitive tweeter.
Here is the spectum of Vera P150/600 in bridged mode measured with 250kHz bandwith:
All the noise up to 250kHz is included in the measurement and if only the noise number is presented to the customer he will assume the expensive class A amplifier will be more silent than the Vera P150/600 class D amplifier.
When limiting the bandwith to a very conservative 40kHz which is much higher than we
actually can hear and what the tweeter
actually can reproduce the table is turned and the noise level on the bridged Vera is about 50uV. The spectrum now looks like this.
Which one of these amplifiers will give the customer the
actual audible lowest noise level? Which one of the presented information gives the customer the best advice?
250kHz bandwidth or 40kHz bandwidth? John?
Reducing the bandwidth to a more realistically 20kHz gives us 30uV:
About THD
(All noise measurements above is in bridged mode by the way. )
Because the feedback is reduced at high frequencies, there is no argue that high frequencies are the weak point for class D amplifiers.
But how severe is it?
Here is the output when delivering 8kHz with 600W power into a 8 Ohm load. One with 40kHz bandwith and one with 250kHz.
Which one of these two measurements gives the customer the most informative information about THD+N?
The one with 0.0007% up to 40kHz, or the one with 0.0183% up to 250kHz?
Unless you are a bat, the 40kHz bandwith is far more relevant than the other one, and is not that exactly the whole point?
John, you can argue all you want about this, but please do not accuse us for cherry picking measurements and misleading customers. I hope the measurements presented here show that class D is not so bad. Is it?
