First, we
do not show cherry picked plots!
The first plot in post #85 is done at 250W into 4 Ohms which is pretty close to rated power of: "270W with maximum 0.0007% THD+N @ 1kHz".
That plot is bandwith limited to 20kHz and show us what we
actually can hear. Maximum audible distortion is 0.0012% around 5kHz
I can produce any plot you request as we have nothing to hide.
Her is a plot I made today from a random sample from the production line.
270W power into 4 Ohms load at 20kHz with the instrument configured to measure everything up to 250kHz. No filter of any kind is installed between the amp in the instrument.
It is very important to understand what we are looking at here. In my experience many people do not understand what 0,035% THD+N at 20kHz actually mean. For some reason they think that the (barely audible) 20kHz tone is somewhat distorted and will "sound" different, but that is not the case. The reason for that is that the distortion occurs at frequencies above 40kHz and will be completely inaudible unless you are a bat.
* First, we have the power. The test tone is 20kHz at 33V. This equals 272W (33^2/4=272W).
* To increase accuracy, a filter inside the instrument mutes the 20kHz test tone with a very narrow band filter before the THD is measured, but we can still see remains of it at 0,15% (50mV)
* Then we can see all the harmonics at 40kHz, 60kHz and so on. The highest one below 200kHz is the 3'rd order at 60kHz with 0.03% (10mV). The second order is only at 0.004% (1.3mV)
* Note that there is absolutely nothing in the complete range of human hearing below 20kHz. Not a single thing above 0.0005% (0.17mV).
In fact, any normal human would hear exactly
nothing when feeding a speaker with this signal since most of us has lost the ability to hear 20kHz a long time ago. Not to mention the next signal at 40kHz at only a very small 0.004% fraction of the 33V 20kHz signal.
(Do not try this on a normal speaker as it will melt the tweeter in seconds
I do not understand how you realistically can think that a x'th order harmonic distortion at 43kHz, 75kHz or 150kHz can affect sound quality? We cannot hear it and the levels are so low they cannot damage or heat up tweeters either.
We could of course add a warning in the manual that if you are looking for an amplifier with very little distortion at inaudible frequencies you should look elsewhere.
