- Joined
- Oct 10, 2020
- Messages
- 804
- Likes
- 2,634
Recently I was looking for a cheap ADC and found a generic, unbranded one on eBay for just under 10$ (UPC: 6927373037416). Here's a few pictures of the device:
My plan was to use an ADC to connect my turntable to a digital input of miniDSP OpenDRC-DI, but I didn't really want to spend much on this and just hoped the cheapest one I find would be satisfactory
The measurements you'll see next were done with the RME Babyface soundcard, first generation - measured here. The ADC was connected to optical SPDIF input of RME Babyface, clock source was the optical input (i.e. ADC) and the sample rate was 48kHz (native sample rate of ADC). Unbalanced/headphone output of RME babyface was used as the signal generator. The performance of the ADC varied significantly based on the type of PSU used, and in these tests I used a powerbank to power the ADC and get the cleanest response. If using a 'dirtier' PSU the noise would increase by 5-6 dB and dynamic range would go down by a similar amount.
Let's start with the basics, RMAA measurement summary (input level set to recommended -1 dBFS by reducing RME output level by ~7dB):
As we can see, performance was not very good - and this is the best I was able to get.
Here's the frequency response:
As we can see the LF -3 dB point is already at 55-60 Hz (not the same for the two channels), and the -6 dB point is in the mid thirties - quite disappointing. Good news is that there is no visible ringing in the HF, the response looks pretty smooth there.
Next let's see the spectrum of a 1 kHz sine at -1 dBFS peak:
As we can see, there's a lot of noise and non-harmonic tones in it, and we can even see pretty high level IMD products around the test 1kHz tone. THD is also pretty high at this level, dominated by the 2nd harmonic.
Let's look now at the THD vs level sweep at 1kHz:
We can see that THD minimum is achieved at only ~25mV input (0,006-0,01%) and the ADC starts to clip around 0,8V. So not a lot of headroom, though I guess it should be OK to digitize a phono line output (mine is specified at 200 mV nominal at 1 kHz).
Lastly let's look at the THD vs frequency at two input levels, first -17 dBFS RMS (~0,1 Vrms):
And then at -5 dBFS RMS (~0,4 Vrms):
As we can see, distortion is mostly dominated by the 3rd harmonic at the lowest frequencies (which doesn't seem to be modulated by level), and then is taken over by the 2nd harmonic, which increases as input level increases. Otherwise there does not seem to be much frequency dependency of distortion (total THD level seems pretty constant above ~200 Hz).
All in all not a very impressive showing, but on the flip-side it is a pretty cheap device, so it could probably come in handy in non-critical uses.
In my case I decided not to use it with my turntable - after I plugged it in I felt the added distortion and lack of bass was audible - though it's hard for me to say if it was just bias from seeing the measurements first as I'm pretty sure even this performance is probably quite a lot better than what my turntable can achieve. Anyway, for my peace of (OCD-ridden) mind I kept this ADC out of the system
EDIT [2021-06-05]: Added a comparison to the RME ADC (measurements and clips) in post #8.
