Speaker Listening Tests
B4, why not to save the reader the search, and provide manufacturer spec. It states down to 40Hz @ - 3dB. test shows like 70 Hz. Big deal.
It states it's min. impedance is 3 ohms. the test show 2.7 ohms (10% lower). No Big deal.
The sensitivity is stated as 92 dB/w/m. Do not recall such test.
The manual: https://www.trianglehifi.com/wp-content/uploads/2019/08/TRIANGLE_ESPRIT-Ez_UM.pdf shows on page 28 (ENG) the recommended
placement. it also has (by adding distances) room recommandations. Were they kept?
This has a major significance to how a speaker would sound. Room size and placement...
It is important to say what were the other system components, participating in the listening test. Just to give a clue and to enable someone to reproduce the listening session. NONE!
If the Amp. would be given (DF), the speaker cables gauge and length would become significant. They are always significant, but by having that info., we could say how far they were from the calculated requirements (Yes, there is such a thing).
Compare to another set of speakers, cost 10 times, ($24,000.-) is not a fair fight. Not that I care for the Triangle Esprit Antal Ez , but I do care for being fair.
If my memory calls correctly, there were speakers of this price level ($ 2,000 to $3,000 price range) or even less expensive, that been approved.
Why not using the same colored bar graph, that could position the Triangle Esprit Antal Ez among its competitors.
A speaker for $2,400.- is still not expected to go down to the very low bass (below 40 Hz). A complementary sub would do it the justice.
Way better than EQ. A $24,000.- Is expected to have a down to 25 - 30 Hz bass, or better.
This comment and comparison is kind of bathering. A 10 times scale is not a way to go (down, to $240.- or up to $24,000 or the next leap of $240,000).
Two models of A). BOSE 901 (https://products.bose.com/pdf/customer_service/owners/901iii_guide.pdf) and B). KEF 104.2. came with a small EQ box. The KEF was called the Kube. (https://www.hifiengine.com/manual_library/kef/kube-1042.shtml).
None was continued or reached the 10 best speakers ever, or the hall of fame. A point to think about.
