Oof, got an issue that I think is with PA5 4 months in. All a sudden 2 days ago, the left speaker started making noise. Used to be silent. It usually sounds like noise with intermittent popping noises. Sometimes it'll pop and all the noise will disappear for a while. Popping and noise aren't super loud but any level of audible noise is unacceptable, and I can definitely hear it from sitting position 19in away (especially the pops, even if they aren't super duper loud). Weirdly enough, 2 days ago I even got some noise that sounded like strong wind being blown through a crack.
This happens only to left channel, never to anything hooked up to right channel (even when I switch the speaker hooked up). It happens when nothing is hooked up to dac (so it's just pa5 connected to power + left channel). Nothing changes if I switch inputs on pa5 or if I turn the volume knob up or down. When I turn it off and back on, sometimes the amount of noise will temporarily increase for about 3 seconds and go back down to normal. Sometimes noise just goes away for seemingly no reason. I'd say left channel has problems maybe 25% of the time throughout the day.
Sounds like an issue with pa5 correct? If not I don't see how this only happens on one channel, and only to whatever is hooked up to left channel, even when pa5 is not hooked up to anything else but power. If my house's power is garbage and it's getting leaked over a balanced connection, why is it only the left channel that has issues?
Has anyone experience with RMA experience for Hifigo? What annoys me about such issues is A) long downtime for company located far away and B) intermittent issues that I fear sometimes RMA department won't pick up.
