Eggs Ackley
- Joined
- Sep 20, 2021
- Messages
- 152
- Likes
- 267
I would also swap the speaker connects left to right and see if the noise moves to the other speaker.
For the first unit, i completely disconnected DAC and Pi streamer; Only equipmet connected was PA5 and speakers (Kef Q300). New quality cables (from worlds best cables). Static was consistently present. Switching to my “backup” rig (Pi 4 + hifiberry DAC HAT + Amp HAT) eliminated the issue, so i'm confident it's not a problem with the speakers.Perhaps the issue is with your system. Have you done any trouble shooting beyond the amp?
I suggest adding a little more work to identify the cause.
Turn off the power of the PA5 and disconnect all the cables connected to the input terminal of the PA5.
The PA5 and speakers remain connected.
The only cables connected to the PA5 are the AC adapter cable and speaker cable.
In that state, turn on the power of PA5.
If you still hear a lot of noise from the speakers, it's probably a PA5 failure.
Or, even if the PA5 is normal, the noise may be unacceptable.
If your speakers are very efficient.
In that case, it is difficult to use PA5 in your environment.
I have had the exact same popping/crackling issue on my PA5 for about a week.
Left channel only as well.
I think I read that someone else had this issue a few pages back in this thread.
Just wondering, to those who have this issue: Did you buy it very early on, only a few days after release? Do you also have a loose speaker binding post? Could be a batch problem...
I will enquire with Shenzhenaudio about a return? Anyone has some experience with them?
Thxs BAA. Worth noting.I had PM'd JohnYang before posting to this thread, however I did not get a response.
Was it after the 25th of March?I had PM'd JohnYang before posting to this thread, however I did not get a response
March 26th.Was it after the 25th of March?
Link? To the teaser photo, I mean.View attachment 199152
My guess is a dual mono Benchmark competitor in terms of numbers.
It's being discussed in this thread;Link? To the teaser photo, I mean.
Hopefully any review sample will be randomly plucked from a busy production line.View attachment 199152
Or they are pushing it too hard which leads to some people having faulty units.Open it up! There is new technology inside hat measures way better than TPA3255.
Marketing mumbojumbo from Shenzenaudio
"PA5 has The newly developed Class D amplification circuit which uses multiple novel optimization techniques to fully push the performance and output power to the maximum. The new circuit provides crisp, clean and deep sound with completely inaudible noise floor. The fully balanced structure makes PA5 no more hum, no more noise, no more ground loop."
Mine has never become more than slightly warm either. It gets a little warmer than the L50 headphone amp, but never hot. I don't know how much power I'm asking it to deliver, but I'm running with the volume at maximum and around 12 dB of attenuation before the signal reaches the E50 DAC (in DAC mode, so full-out). We'll see how long it lasts, but so far, so good.What I find interesting is some people are reporting that the unit runs quite hot. Mine has not become more than just slightly warm, even when testing it at 40-50W continuously for a few minutes.
