Topping PA5 Review (Amplifier)
Labjr
Dear @amirm, if you don´t return this amplifier, could you please ask Topping if you could open the châssis and show us the innards?
JP
Does anyone think they're going to see anything revelatory inside this amplifier? Probably a couple of TPA chips on a PCB. The magic is in the implementation and layout. Doubtful it would be obvious to any non-engineering person or even visible because of the solder mask.
Lambda
Really wish for a stereo amp with sub output and DSP: high pass for stereo, low pass for sub. I don't see one yet, at least from Chinese companies.
YES! But that seems more of a feature for a DAC than an amplifier? IMO it's a much needed feature for the E50/PA5 stack. Hope Topping in the future has a DAC with proper DSP.
howard416
Yep, it's a pretty nice feature to have. But, it's also a great beginning-level DIY project... an inline active xover + summing box with a basic DC power supply, proto-board, and a few opamps will do the job and is only a few hours of work if you have a soldering iron and some basic tools.
Which is not to presume that anyone is ready or willing to embark on DIY, of course.
pma
Prague
Yes - but your unbalanced DAC might not output enough volts to drive the amp to full power.
I use this to drive my UcD180HG amp with balanced input from Topping D10s. Shortest cable between D10s and the preamp. Maybe a hint for Topping or other commercial audio company.
howard416
Regarding the increase in THD from about 3 kHz on, this is like many Class AB amps or even the Neurochrome composite amps: the feedback loop begins to run out of bandwitdh.
In fact, I wonder if the composite approach was taken here, hence an external feedback loop wrapped around a chipamp. Maybe this can be done with UcD amps, too. After all, their bandwidth is not that much worse than an LM3886.
Just to keep things in perspective, at this level of performance you won't come anywhere near to being able to hear the H2 and H3 distortion products, so at worst you'd be trying to hear the H4, H5, ... which would start at 5 kHz and downward. If you're lucky and still have hearing to 20 kHz. And the 5 kHz curve shows us that HD should be inaudible overall based on the expected higher-order HD profile.
If you meant to simply observe that phenomenon, please ignore my paragraph above.
sarumbear
Yes. This thing is an integrated amplifier, so includes some basic pre-amp functions.
Most DACs these days also have integrated preamps and can be connected to power amps directly.
This is something I thought about but the big problem is that DIYers have no way to validate if it's working properly. I mean we're all here because we rely on measurements. Would love to have an affordable commercial product that includes proper crossovers for 2.1.
howard416
If you have a signal source (e.g. PC) and a relatively accurate DMM, sure you do. Just calibrate the output voltage coming from your sound card (or equivalent interface), and read the voltage coming out of the xover box while you vary the signal frequency. With a series of measurements you can get enough data points to interpolate the transfer function.
E.g. if you play a 10 kHz sine you should expect full voltage out of the "main" output and no voltage out of the "sub" output. Conversely, at 20 Hz, you should expect the opposite, depending on your filter implementation and how low the xover frequency is.
EDIT: Now, if you were to ask for phase control, well, at that point you should really just consider discrete DSP.
pma
Prague
This is not true at all. You do not need AP to “validate if it is working properly”. A good $200 soundcard and $200 digital USB scope is all you need. Plus knowledge and this cannot be shown in $. Same as Topping competes to overpriced audio, one may do enough with cheaper instrumentation than AP.
howard416
This is not true at all. You do not need AP to “validate if it is working properly”. A good $200 soundcard and $200 didital USB scope is all you need. Plus knowledge and this cannot be shown in $. Same as Topping competes to overpriced audio, one may do enough with cheaper instrumentation than AP.
Beat you to it. :)
Reactions: pma
david123
Certainly could be in the DAC. Wherever it is, as long as it is good for 2.1 bass integration.
Ok, let me spend $400 +time to learn the requisite knowledge to validate a DIY project. /s People spend money on things that work out of the box so they don't have to do that, lol.
david123
Another problem is also the time invested. Busy or lazy , sometimes I just want something ready and work out of the box.
pma
Prague
I do not speak about you specifically, but about your generalization. One should speak about topics he knows something about.
antcollinet
UK/Cheshire
Another option (for those without requisite DIY skills (or time) would be to get this from AliExpress:
Or similar circuit in a finished product:
