1, Yes, opa1612.@JohnYang1997 Hi there John don´t know if you can confirm two thinks (of this topic).
1. Are the signal amps of DX5 all TI OPA 1612A like the ones in E50?
2. What's the frequency of the DSD cut-off filter in DX5? (if any)
I'm deciding on buying the DX5 or SMSL M500 MKII
Thanks
Thank you.1, Yes, opa1612.
2, I have not measured it. But it appears to be about 47khz and it scales with the dsd rate.
-note that if you got an early E30, the newer one hasn't got "better" s-pdif compatility, it's more fixing a problem with later revision E30s that use different s/pdif receiver chipOps, came quite late but read almost all of the thread.
I happily use an E30 first release way more than one year without any sorta problems, all it needs it a good LPSU.
It's anyway interesting to know that a new release of it is on market, twin-dac chipped, better s-pdif compatibility and a very few bells and whistles as its ancestor.
Just a question, if I correctly understood, will this new release implement a brand new power stage inside of the case?
I mean, would the whole DAC performance become a little less critical than the previous one in matter of supplied 5VDC quality?
What is your understanding for how out of warranty units should be handled (I assume there would be some type of charge)? Also, any chance Topping can work with Apos to improve Apos support's response time?Usually you send back the broken one and get a new one.
Thanks for the clarification, Veri.-note that if you got an early E30, the newer one hasn't got "better" s-pdif compatility, it's more fixing a problem with later revision E30s that use different s/pdif receiver chip
-the better power supply squeezes out that bit of SINAD difference between E30/E30-ii (besides the DAC chip revision).. 112>116dB, nothing to worry about
Thanks for the laugh! It was like someone was forcing him to use it. I love his review of the remote control. Is it that hard to point it at the device? Honestly, I forget mine has a remote. It just sits in the drawer. And don’t get him started on the button on the front. He has troubles with this too. Ahh good times!It seems that the new Topping E30 II is not to everyone's liking.
He has some excellent points and some stupid ones. I won't ever buy another bus-powered device with audio outputs. Underpowered outputs suck.It seems that the new Topping E30 II is not to everyone's liking.
He got a point with the required power supply.It seems that the new Topping E30 II is not to everyone's liking.
Armin (and anyone else!), HELP! I am considering purchasing the Topping E30 II DAC with one concern I would need to resolve: I would be using the USB only as a potential input, not as a power source.This is review and detailed measurements of the Topping E30 II DAC. It was sent to me by the company and costs US $149.
The single "SEL" button powers on the unit (touch sensitive) and selects input. Some combination of power cycling and that button lets you change menu settings but bets to use the included remote:
There is no power supply included. There is a USB to 5 volt barrel connector giving you the choice of how you feed it. I started with my USB hub built into the monitor but got the best results with a Samsung USB charger. Your situation may vary as you don't have an analyzer in front of the unit.
Topping E30 II Measurements
This our dashboard using Toslink input:
And now USB:
Depending on grounding, I could almost get up to 118 dB SINAD. But going with what we have, performance is still excellent:
Here is our dynamic range:
And IMD test:
Jitter performance is very good with USB input:
But both Toslink and Coax showed significant 250 Hz jitter components:
As noted, these are inaudible though as the typical level is below threshold of hearing/masked.
Linearity shows a hair noise but otherwise is excellent:
Multitone test highlights the very low levels of distortion:
Here are the included filters:
Using the default F2, we get this wideband distortion+noise vs frequency:
Not state of the art but still very good.
Great to see my favorite "orange LED" DAC updated. Performance is improved across the board compared to Topping E30. Yet the price has hardly changed. We are talking about near state of the art performance in a finished DAC selling for just $149. With good looks to go with it.
I am a bit bothered by Toslink and Coax Jitter. AKM chip used here doesn't resample as ESS does so any issues there travel right through the DAC. Fortunately it is not an audible concern and for someone like me who uses USB as the primary input, non-issue.
I am going to put the Topping E30 II on my recommended list.
And now USB:
And IMD test:
Armin (and anyone else!) HELP! I am considering the Topping E30 II DAC but need to resolve one concern: I would be using the USB as a potential input but not as a power source. The device provides a plug-in point for an outboard power adapter but apparently the adapter is not provided. I'm at a bit of a loss at choosing an appropriate adapter. I was able to download a PDF of the user manual but found it unhelpful. The only thing that is (semi)-obvious is that is needs to provide 5 volt DC. In other situations I've had serious challenges getting replacement/backup power adapters, even to the point of units with absolutely identical specs (volts/amps/watts) but different barrel connectors. Go figure! Like I said, HELP!This is review and detailed measurements of the Topping E30 II DAC. It was sent to me by the company and costs US $149.
And now USB:
And IMD test:
And apologies for the somewhat duplicated messages. I thought I had lost the first draft. Duh! My inner Homer Simpson. - By the way and not really relevant to my current inquiry: I recently stumbled on a post/thread titled something like "More humour, please!" There was some really good stuff. Mostly cartoons, I recall. One I particularly loved, a listing of stock market indicator including a per meter increase in the price of audio cables! But now I've lost the link. Anyone have have this on hand?Armin (and anyone else!), HELP! I am considering purchasing the Topping E30 II DAC with one concern I would need to resolve: I would be using the USB only as a potential input, not as a power source.
A 5V 1A phone charger or a spare USB socket on your computer should be fine.Armin (and anyone else!), HELP! I am considering purchasing the Topping E30 II DAC with one concern I would need to resolve: I would be using the USB only as a potential input, not as a power source.
I for one welcome the power supply as I'm not using a computer that supplies both power and music files but a DAP for music and I get to get power via the power supply. Neat.He got a point with the required power supply.
it's 2022 things shuld be USB Powered.
But why can't the power supply be a USB power supply in your caseI for one welcome the power supply as I'm not using a computer that supplies both power and music files but a DAP for music and I get to get power via the power supply. Neat.
some DAPs fail to act as a power supply... the newer ones do. Like the sony-nwa45, one the DAP doesn't provide usb. I have to use an adapter but the usb connector only use the data portion of usb hence the need of power. Anyway taking power from DAPs drain its battery faster. Better to use the power supply.But why can't the power supply be a USB power supply in your case
I have been using my Topping E30 since 2020, everything works perfectly, no problems. I'm thinking of getting Topping E30 II or Topping E50. By the way, I use my E30 with an old Topping A30 amplifier, they don't make it anymore.He has some excellent points and some stupid ones. I won't ever buy another bus-powered device with audio outputs. Underpowered outputs suck.
Usability issues are real when it comes to the topping devices.
It is in a cheap box, has poor user controls, and has no features to speak of.
On the other hand, if it doesn't die in the first 6 months, it is a good little standalone box that does its job.
You could buy a cheaper box that does the same thing with no audible differences from the same company or others.
Calling it shit is unfair. It measures amazingly well and as a result, puts real pressure on other manufacturers to step up their game and that is a good thing.
Should you be purchasing DACs based on feature sets rather than inaudible measurement differences? Most likely.
Didn't stop me from buying the L50 though.
Thanks for your response but it doesn't address the fact that I don't want a DAC that has to be joined at the hip to my computer or to a phone charger. I prefer to have a proper wall wart that connects to the barrel connector port on the Topping DAC. Problem is, it seems that a wall wart is not provided and, as I explained, getting a proper power adapter (wall wart) can be challenging.A 5V 1A phone charger or a spare USB socket on your computer should be fine.
