Upsampling 48k based rates to 1bit 12.288 MHz is significantly lower CPU loading than to 11.2896 MHz.
So it's nothing to do with available music content.
So I just wanted to ask if DSD256x48 or DSD512x48 works with E30. Does it play music.
HQPlayer is free to try. It is fully featured for 30 minutes and then you can just restart the player again.
Can you test (for free)?
It seems this few months old question remained unanswered. E30 is able to play 48k based DSD content but there are some bugs since developers didn't count with the HQPlayer community and didn't test that.
Test files for those sample rates are not easily available since standard DSD downloads or SACDs use 44.1k based sample rates. For testing with 48k based DSD rates one can use upsampling in HQPlayer Desktop (on the fly during playback) or one can create test files with HQPlayer Pro by converting from other format (PCM or DSD). Free trial is sufficient for that in both cases.
Now about the bugs:
a) DOP mode (DSD128 6.144 MHz, DSD256 12.288MHz)
48k based DSD content plays OK but E30 display shows 11.28 instead of 6.14 for DSD128 and 22.57 instead of 12.28 for DSD256. For DSD128 the Topping ASIO driver Control Panel shows 384000 Hz (that's the correct expected value for DoP DSD128).
b) native DSD (DSD128 6.144MHz, DSD256 12.288MHz, DSD512 24.576MHz)
If 44.1k based content (PCM or DSD) was played before, after switching to 48k based DSD sample rate (say DSD128 6.144) the E30 display shows 5.64 and music plays slower than it should in the ratio 44.1 / 48. The work around is to switch to DoP and back. Then the music content will be played without issues but the E30 display shows 11.28 instead of 6.14 for DSD128 and 22.57 instead of 12.28 for DSD256 (like in DoP). The ASIO driver control panel shows correct DSD sample rate (6144000 Hz for DSD128, 12288000for DSD256). If 48k content DSD content was played before, the switching to DoP and back is not needed to get correct playback speed.
DSD512 24.576MHz does not bring any sound from E30. HQPlayer is playing and sending data into the DAC, ASIO driver control panel shows correct sample rate 24576000 Hz and it seems the E30 XMOS receiver is getting data, but display incorrectly shows 45.15 and no sound is coming from analog outputs.
The 44.1k based DSD512 content plays without issues in native DSD mode.
There are many DSD capable DACs which correctly play 48k based DSD content. Some manufacturers repaired things after user feedback and then new models are already capable of 48k based DSD from the beginning. Since Topping has also higher class DACs like the D90 one, I suggest to solve these issues to make Topping DACs more attractive for HQPlayer users and generally for users demanding the highest class DACs and solutions. Otherwise requests of this type will come again and again.
