I am fairly new to new to Foobar.I failed to actually INSTALL the components rather the merely dropping them into the components folder. Now DFF\DSF files play directly. No DOP or Wasapi wrapper. I like my drugs uncut and WASAPI always seemed like adding baby laxative to the flakey goodness that is DSD.[
I have got J.River finally working as a pure Asio player without too many bufferings. I've got 6k DSD files from 64 through 512. I want to use Foobar as it handles other very large files (5.1 24\192) better the J. River. So far Foobar is still silent even using your Asio settings. I've tried manipulating this without anything but silence
Honestly my view is that the amp is much more important than the DAC. There are many, many superb DACs like the ones I mentioned. You can get a cheap one and get something balanced like the Modius much later on (if you even want to!). So yes A90+ budget dac is the way to go the way I see it.@Veri thanks for that idea..
so u say that the dac part is not so important?
You are using foobar2000 foo_input_sacd-1.2.3 This version does not support native dsd outputI needed a DAC, where I could roll opamps, had a balanced out and would play DSD up to 11
Soundmanager/properties/levels click on levels next the speaker icon and you should have a left and right channel to adjust.hello. is there a way to adjust chanel ballance ? i cant find a way to do it. i mean whole windows setup. tried using soundvolumeview.exe , but it doesnt work.
is it topping driver issue most likely ?? my other DAC Audio GD 11.38 works ? Could it be due to different usb chip ( amanero on Audio gd ) and/or dual dac chip 11.38 vs single chip DX7Pro ? Already wrote email to topping china.Soundmanager/properties/levels click on levels next the speaker icon and you should have a left and right channel to adjust.
Edit : just noticed it won't show left and right channel for dx7 pro (strange)
one more thing i noticed. Audio gd is showing as digital audio output in windows volume mixer , yet DX7 Pro is detected as speakers.is it topping driver issue most likely ?? my other DAC Audio GD 11.38 works ? Could it be due to different usb chip ( amanero on Audio gd ) and/or dual dac chip 11.38 vs single chip DX7Pro ? Already wrote email to topping china.
You control the balance of the channels in the amplifier, and for this it is created.so split stereo cable to separate mono cables and use potentiometer to balance the sound level ?
Was the volume max in pre mode?An absolute noob question. Just got the DX7 pro. The input source is my desktop PC via USB. I am using the RCA out to send sound to my Klipsch 2.1 system. The line out RCA has two settings - PRE and DAC. Can someone please tell me what the difference is between both these options aka how is the signal getting processed in both these options. I had it on PRE by default and after changing it to DAC, I feel the music sounds a lot better coming out of my Klipschs. Is it that when it was in PRE, it was just passing through the signal and now that I have it on DAC, the DAC chip is actually doing its magic? Some info would be highly appreciated.
Thanks for the info. No, the volume was not maxed out in PRE - and it automatically disables the volume in the DAC mode. I tried again to ensure that it was not a placebo effect. I still feel the pure DAC mode sounds a little better. Changed it back to DAC.
