The DX3Pro+ does not output balanced, just regular RCA.I have this for my headphones and now also got Topping PA3S for speakers. Help a newbie please, how am I best connecting them? I was going to try TRS balanced for the first time, is two of These what I need?
RCA->RCA would be the default way to connect these.I have this for my headphones and now also got Topping PA3S for speakers. Help a newbie please, how am I best connecting them? I was going to try TRS balanced for the first time, is two of These what I need?
If you get GND loop noises that way, then it would be worth trying RCA->TRS cables instead, with specifically this configuration:
That might get rid of the hum.
If rca->rca has ground loop, your configuration won't solve the issue much. Better to use this method:RCA->RCA would be the default way to connect these.
www.audiosciencereview.com
You can check if your unit is on the latest firmware (v1.25):i often get connected, but no sound comes out. So I have to disconnect, “forget” the source device, then re-pair the device. Frustrating! I wonder if it can be fixed with a firmware update?
I have the latest firmware on my two units. Both have the same issue. The source device connects to other bluetooth devices just fine, so the issue appears to be a systemic problem with the Topping. Too bad, as it is otherwise an excellent product.You can check if your unit is on the latest firmware (v1.25):
https://www.tpdz.net/newsinfo/663552.html
The chances of a new firmware update beyond that are slim.
It's been 1.5 years since the last update after all.
I like the idea of the DL200, but in practice this is a much larger much heavier unit than the DX3 Pro+ that has around 2.5x the footprint. Not nearly as well suited to desk use or nearly as portable. The DL200's amp is also less powerful, which is fine but harder to accept on a bulkier unit. The DL200 looks like an awesome value for it's price, but the form factor kind of kills it for me.chip updates such as ES9039Q2M / XMOS XU308 gives zero audible benefit. Instead, having a balance outputs (which can be done at near zero cost) would greatly make the device more usable in a lot of cases. But I don't believe topping would be willing to do that, as that hurts the sales of their mid-priced devices. On the other hand, SMSL DL200 or C200 achieved this at same price range. I would just get one of the latter two SMSL devices if I'm new to the market.
C200 is not too large. and it has much better component (PSU for instance) quality than dx3 pro+. the adapter of dx3 pro+ is just crap. LED too -- a few users reported it fails.I like the idea of the DL200, but in practice this is a much larger much heavier unit than the DX3 Pro+ that has around 2.5x the footprint. Not nearly as well suited to desk use or nearly as portable. The DL200's amp is also less powerful, which is fine but harder to accept on a bulkier unit. The DL200 looks like an awesome value for it's price, but the form factor kind of kills it for me.
C200 does have comparable dimensions to DX3 Pro+, but like you said it has advantages and disadvantages vs the DX3 Pro+. The internal power supply on the C200 is definitely an upgrade, but most of the internal hardware (ESS, XMOS, BT etc.) is from the prior generation of amp dacs like the DX3 Pro+ (ie. not the current generation like the DL200). The C200 is only 1.5 years old vs the DX3 Pro+ which is 2.5 years old so I'd guess it'll be longer before the C200 gets an update.C200 is not too large. and it has much better component (PSU for instance) quality than dx3 pro+. the adapter of dx3 pro+ is just crap. LED too -- a few users reported it fails.
I agree dx3 pro's amp is more powerful. it is possible to add balanced output to topping dx3 pro in the same package size. I wish topping release one but they are not willing to do that.
For clarity I'm not implying that I expect the chip updates themselves to make an audible benefit. It's just a clearly identifiable generational break.as I said earlier, chip updates such as ES9039Q2M / XMOS XU308 gives zero audible benefit.
on the other hand, balanced outputs do give huge improvements on noise reduction. A lot of professional equipments (studio monitors for instance) only accepts balanced signals.
Had the same problem with my DX3Pro+. But that was the least of it's problems.I often use the bluetooth input (LDAC) to play Apple Music when I’m too lazy to use wired IPad-> Topping. Apple Music + LDAC sounds great. But holy cow—getting connected to the Topping’s bluetooth is iffy many times. i often get connected, but no sound comes out. So I have to disconnect, “forget” the source device, then re-pair the device. Frustrating! I wonder if it can be fixed with a firmware update?
Once the connection is good, no dropouts afterwards.
Do you recomend Topping dx3pro+ ? My jds labs atom dac is broken and I am searching for a new amp (or dac/amp). What are the problems the topping dx3pro+ has?Had the same problem with my DX3Pro+. But that was the least of it's problems.
