qwuzzy
So would this be a bad buy to use with 32ohm headphones? Not entirely sure what the clipping at low impedances means and if it's recommended or not.
It gives 1.5 watts before clipping at 32 ohm. Which is a lot.So would this be a bad buy to use with 32ohm headphones? Not entirely sure what the clipping at low impedances means and if it's recommended or not.
The DX3Pro+ doesn't actually struggle with <32Ω loads, as WolfX-700's APx555 measurements show:So would this be a bad buy to use with 32ohm headphones? Not entirely sure what the clipping at low impedances means and if it's recommended or not.
Is there an easier way to browse the L7audiolab site? auto translation is not great. Are his measurements posted on this site too?The DX3Pro+ doesn't actually struggle with <32Ω loads, as WolfX-700's APx555 measurements show:
Link
When compiling the data into Max Vrms vs Load graphs, it becomes obvious that something went wrong during Amir's test:
What exactly went wrong, I can't say. Perhaps Amir didn't cool the Amp adequately to compensate for the synthetic nature of the test signals, or perhaps the dummy load wasn't attached properly (oxidized contacts).
What I can say though is that Amir's 12-600Ω Load sweeps have produced sketchy data ever since they were introduced, so at least in this case, I would genuinely disregard them and trust Wolf's graphs instead.
Some of them are posted here as well.auto translation is not great. Are his measurements posted on this site too?
You can open the menu and choose between Desktop and Portable devices, then scroll through all tests of that category in chronological order:Is there an easier way to browse the L7audiolab site?
I prefer SMSL C200Is this still the go to choice for a combo DAC/AMP at $200? Debating the DX1 but the DX3 Pro+ seems to offer a lot more power.
What makes you prefer that over the DX3 Pro+?I prefer SMSL C200
It runs cooler and has a more responsive remoteWhat makes you prefer that over the DX3 Pro+?
If you need two coaxial digital inputs, it is.Is this still the go to choice for a combo DAC/AMP at $200? Debating the DX1 but the DX3 Pro+ seems to offer a lot more power.
Are there any DACs with dual USB inputs? I would love something that could switch between my work and personal computers.If you need two coaxial digital inputs, it is.
latest driver is 5.62In general, using driver v.5.57 from the manufacturer, I have a crunching sound when watching a video in the browser, a strong specific crunching sound, interruptions, shocks, I don’t know how else to say it, obvious distortions. If you remove it and leave the driver that Windows automatically pulls up, then this problem disappears, but with this driver it seems that when rewinding in wasapi mode the overtones are louder, and in general I would like a normal driver. Has anyone had this problem? There even seems to be support for Topping on the forum, what does she think about it?
Thanks, I'll try it now
