TOPPING D90 III Sabre DAC Review
Rate this DAC:
    Votes: 13 3.0%
    Votes: 33 7.6%
    Votes: 108 24.9%
    Votes: 280 64.5%
I've been looking forward to this test for a while, and read it with some anticipation.
They've succeeded in their very focussed mission to make the cleanest and quietest DAC that it's possible to make. Succeeded where so many others have failed.
But the audience is hard to please.
Yeah, but what kind of golden eared audiophile claims to hear the difference between 123 sinads and 115 sinads? You can get the latter for $129.
I gave the D90 III five stars because they finally added triggers. :)
A Roon interface gives you both streaming and PEQ...
- Rich
And monthly payments...
And you cannot use Roon with your tv.
So being able to do EQ in device (being dac or other) is really neat feature.
Technically perfect.
At this price range I would start looking into eg RME with tons of features, good HP amp, excellent customer support and quality.
If Topping wants to play in that league they have to work on the latter two.
Edit. Or even latter 5 ie everything but SINAD ;-)
I agree there are a bundle of DACs that measure within an inch of each other such that it makes no difference except for the feature set. and that’s where my money went, I have the RME for the features and support. but I might be swayed by something with room correction built in!
The miniDSP SHD checks those boxes for a similar price compared to RME.
Thanks for the review @amirm
There is a separate thread in which the op said that these III devices (D90 and D50) would be upgraded to have EQ capability. Any additional information on that?
"D50 III has PEQ, and D90 III seems to be updated in the future."
Thread 'TOPPING D90 III、TOPPING D50 III' https://audiosciencereview.com/forum/index.php?threads/topping-d90-iii、topping-d50-iii.50539/
This feature + D70 Pro interface might be a better reason to upgrade my DAC, not a 0.3dB SINAD improvement over their last record…
The same sort of mature wealthy male over-achiever who doesn't know how to spend all his money so buys the latest Porsche 99x GT3 that can lap the Nurburgring one second faster than his old car, but who will never take it anywhere near a circuit.
Although usually that sort don't care about SINAD or know what it is, and instead they buy expensive, cool looking, well marketed DACs for their looks+price+reputation since typically they have decades without any evolution.
I think most of us would buy Topping DX9 if we had unlimited money rather than say Topping E30.
Add a mixture of YOLO and FOMO and it would be an easy sale. Sometimes the higher priced products also come with better support, documentation, warranty etc..it would be easy to say "why not?"
I'm about to the point that RME is going to go on my list of companies to never buy from. To many people saying get it.
I have had many RME devices for 20 years, I would not recommend them for home hi-fi.
Topping if you read this, can you build a DAC with PEQ and / or a DSP device using your expertise?
Don't knock Porsche drivers here. It has nothing to do with how to spend one's money. Put yourself behind the wheel and you'll wonder why you're only focused on talking DACs. :p
Yes, why not? (I don't own one but would if I wanted to spend that sort of money.)
I'd assume because for that kind of money you could build a small form factor computer and put PEQ software on it and have it feed a cheap audibly transparent dac.
with the proper compontents the pc will give you more possible inputs, and outputs.
assumedly with newer version of AP shows 128dB
No, as I said earlier A-weighting has been applied;
JSmith
