Ok, got it. Thanks again.SNR is the ratio of full-scale output amplitude to output amplitude during silence.
Nothing is playing while the Noise part is being measured.
What is the native rate for the chip’s delta-sigma modulation? 1-bit, 2.8MHz? My guess is that sample rates with the greater processing overhead to decimate & oversample, or Fourier transform, or whatever needs to happen computationally to get them to the native rate would result in higher power consumption.D90 III power consumption at different sampling rates (into XLR into 10k ohm)
176.4 || 0.0855A
192 || 0.0860A
44.1 || 0.0880A
48 || 0.0890A
88.2 || 0.0890A
96 || 0.0895A
352.8 || 0.0910A
384 || 0.0920A
Interesting how 192 is least because 8x = 384
I think it's quite a bit higher than that, actually.What is the native rate for the chip’s delta-sigma modulation? 1-bit, 2.8MHz? My guess is that sample rates with the greater processing overhead to decimate & oversample, or Fourier transform, or whatever needs to happen computationally to get them to the native rate would result in higher power consumption.
Comparing only the measurements of these DAC with the Topping E50, although the TOPPING D90 III Sabre has pushed the limits a little further, overall, the measurements are practically the same. All the improvements are in the millimeters scales, maybe resulting in nuances that a balanced setup/environment would more easily highlight. This may not be the case for most audio enthusiasts, like myself.This is a review and detailed measurements of the TOPPING D90 III Sabre balanced stereo DAC. It was sent to me by the company and costs US $899.
As you can see, the design is what we have know about most of the Topping products. I do wish at this price that we had a high resolution display that showed VU meters and such. Usability would be better that way although the included remote is easy to use. Back panel is as you would expect:
Nice to see Topping continuing to provide trigger support for automatic turn on of the downstream amplifiers and such.
TOPPING D90 III Sabre Measurements
The DAC has two output setting modes. One that provides max of 5 volts nominal and one that is 4 volts. For fairness I tested using the latter. DAC was allowed to warm up which improved its performance by about 1 dB.
As usual, we start with our dashboard:
This is the best performance we have seen from Topping and is in a virtual tie with the previous king of DAC SINAD measurements:
RCA performance is still superb and fully transparent:
Dynamic range is exceptional as you would imagine as it is setting the SINAD:
Multitone shows the exceptionally low distortion:
As does 50 Hz response for compatibility with other sites using it:
Jitter could be a hair better given the performance elsewhere:
IMD performance is excellent:
Linearity is perfect:
We have the typical filters but I would stay with default (F3):
The filter selection impacts wideband THD+N measurements so I stayed with the default:
Story is told....
Topping aimed to capture the top spot in the rankings and it got there, besting every other DAC it has produced, albeit with very small margin. If the cost is not a concern and you are buying a new DAC, might as well opt for D90 III.
I am happy to recommend the TOPPING D90 III Sabre.
It hasn't been the case for me for many years. Now that it's there with indistinguishable audio (for many of us, anyway), how 'bout them designing some helpful usefulness to it?Comparing only the measurements of these DAC with the Topping E50, although the TOPPING D90 III Sabre has pushed the limits a little further, overall, the measurements are practically the same. All the improvements are in the millimeters scales, maybe resulting in nuances that a balanced setup/environment would more easily highlight. This may not be the case for most audio enthusiasts, like myself.
Topping E50 - August 2021 - $175.12 USD - https://www.audiosciencereview.com/forum/index.php?threads/topping-e50-review-balanced-dac.26219/
Topping D90 III Sabre - January 2024 - $879.12 USD - https://www.audiosciencereview.com/forum/index.php?threads/topping-d90-iii-sabre-dac-review.51493/
I went from an E50 (first gen) to a D70 (not a D90, but close enough for me and better looking). Main reason: I needed a pre-amp/DAC with a more robust volume and input control. And I could afford it. For anyone just needing a DAC: get the E50. It does not sound the same, but there a very few people, none of which you or I are acquainted to, who would be able to tell the difference in a blind test. I know I can't. And is difference the same as better? The E70 will stay with me now until it dies, which it has not shown any intent to whatsoever.Comparing only the measurements of these DAC with the Topping E50, although the TOPPING D90 III Sabre has pushed the limits a little further, overall, the measurements are practically the same. All the improvements are in the millimeters scales, maybe resulting in nuances that a balanced setup/environment would more easily highlight. This may not be the case for most audio enthusiasts, like myself.
He goes on and on about the subtle sound differences, I would like to see him pass a double blind test first before he offers his verbose opinions.In this video, the comparison is with SMSL SU 10
This, IMHO, is a step up in appearance. That may help the audio in some sort of feely/touchy way .In some reviews, he is honest when afirms that on basic sets (and rooms too), diferences are hard to perceive. That is why I resist on to upgrade from my Topping E50.
A good DAC like the RME from 20 years ago is still a good DAC. If you want to upgrade for looks or features or connectivity or you will be happy, if you are upgrading for sound quality you may be disappointed .... after the initial confirmation bias wears off. In any case have fun, its what hobbies are about after all.Im upgrading from an RME ADI-8 DS from like 20 years ago.
Get this one for less than US$ 100.00 and check if this new generation worth.Im upgrading from an RME ADI-8 DS from like 20 years ago.
Sounds like you need a connectivity upgrade so make sure your new DAC has what you need now and if you can guess the future. Any of the DACs your are looking at will sound essentially perfect. RME are great DACs , not cheap but great features and service and as you know they will last.I paid little over 2k for an SPL Phonitor. A "profresional" headphone amp that simulates crossfeed, that its mean feature but it has more things.
10-15 years passed and I started messing around with DIY electronics. I ended up building a headphone amp kit the blew away that 2k amp for little over $200. I simulated the crossfeed with goodhearts can opener plugin. This little setup blew away my 2k amp. Which i have somewhere in the basement collecting dust because no one will buy it.
20 Years in technology is a long time.
I also have another problem with the RME unit. It works with ADAT. I do not have an affordable option to connect that to new macs. I have an RayDAT card for that its PCIe.
They are good but WAY out of my price range.Sounds like you need a connectivity upgrade so make sure your new DAC has what you need now and if you can guess the future. Any of the DACs your are looking at will sound essentially perfect. RME are great DACs , not cheap but great features and service and as you know they will last.
