IMO, any amplifier that is brought to its knees by a speaker (unless speaker impedance drops down to zero ohm, i.e. shorted outputs) may not be considered ‘best designed’ … even then protection should kick in and prevent damageI'm agreeing with you while adding there are some speaker designs that can bring even the best designed amps to their knees.
Any ‘best designed’ power amp shall be able to double its power into halved speaker impedance … all the way at least to 2 ohm and have wide enough flat bandwidth to not distort the signal in any way.
That's exactly why we have Amir ... to prove or call that out !As has been widely discussed here, the "doubling" of power is typically a misdirection achieved by lowballing the 8 ohm figure in the first place, a practice that dates back to the 1970s. My old Bryston 3B (1987) allegedly doubled 100/200 but an 8 ohm load tested at nearly 140 watts.
At some point, perhaps 2 ohms as you suggest, but maybe more, speakers that 'bring amps to their knees' are a design fail in and of themselves.
Yeah agree, speakers falling to close to 2 ohm aren't well designed probably either ... good pointAs has been widely discussed here, the "doubling" of power is typically a misdirection achieved by lowballing the 8 ohm figure in the first place, a practice that dates back to the 1970s. My old Bryston 3B (1987) allegedly doubled 100/200 but an 8 ohm load tested at nearly 140 watts.
Yep. A doubling of power when halving the load is technically impossible, at least using bipolar transistors or MOSFET in a class A or AB power stage, even with a regulated power supply. I'm not familiar enough with class D power amps but the limits of the transistors should apply as well.As has been widely discussed here, the "doubling" of power is typically a misdirection achieved by lowballing the 8 ohm figure in the first place, a practice that dates back to the 1970s. My old Bryston 3B (1987) allegedly doubled 100/200 but an 8 ohm load tested at nearly 140 watts.
I agree when we talk about multi way speakers using dynamic drivers. There is no excuse for designs going down to 1 Ohm or less. Some exotic drivers though suffer from very low impedances, e. g. full range electrostatic or ribbon drivers. For those you may need matching amplifiers.At some point, perhaps 2 ohms as you suggest, but maybe more, speakers that 'bring amps to their knees' are a design fail in and of themselves.
Agree ! What I was describing is an aspiration, but due to the losses it will probably never double its power … but it should come as close as possible … or at least be honest and transparent in the published specsYep. A doubling of power when halving the load is technically impossible, at least using bipolar transistors or MOSFET in a class A or AB power stage, even with a regulated power supply. I'm not familiar enough with class D power amps but the limits of the transistors should apply as well.
Probably the biggest design failure of the Original Apogees and Scintillas was the failure to make them actives with matching amplifiers and electronic crossovers.Yep. A doubling of power when halving the load is technically impossible, at least using bipolar transistors or MOSFET in a class A or AB power stage, even with a regulated power supply. I'm not familiar enough with class D power amps but the limits of the transistors should apply as well.
One problem you are up against right away is the simple fact that every amp made has more distortion into lower impedances (people have challenged me on this statement but when you dig into the specs you see that this is true). By this metric there is no 'best designed' amp. Quite often I've seen that distortion described as 'negligible' but IME it isn't. This is because the ear uses higher ordered harmonics to sense sound pressure and in addition assigns them a tonality of 'bright and harsh'. For this reason you can make any amp sound smoother and more detailed simply by having it drive a speaker of higher impedance.Any ‘best designed’ power amp shall be able to double its power into halved speaker impedance … all the way at least to 2 ohm and have wide enough flat bandwidth to not distort the signal in any way.
sure, you are right … amp should aspire and be designed to maintain its voltage gain basically more or less unchanged throughout the whole frequency bandwidth and through the impedance variations of the speakers it is drivingOne problem you are up against right away is the simple fact that every amp made has more distortion into lower impedances (people have challenged me on this statement but when you dig into the specs you see that this is true). By this metric there is no 'best designed' amp. Quite often I've seen that distortion described as 'negligible' but IME it isn't. This is because the ear uses higher ordered harmonics to sense sound pressure and in addition assigns them a tonality of 'bright and harsh'. For this reason you can make any amp sound smoother and more detailed simply by having it drive a speaker of higher impedance.
Also IMO/IME its not important that the amp double its full output power as impedance is halved. It is important instead for it to behave as a voltage source at any volume with which the amp will be played on a given speaker.
Same thing. If its a perfect voltage source it will double the power. And amps are (if they use feedback) close until they start to current limit. Those numbers are at full power. If you try a 100watt amp at 1watt into 4ohms it will put 2watts into 2ohms.Also IMO/IME its not important that the amp double its full output power as impedance is halved. It is important instead for it to behave as a voltage source at any volume with which the amp will be played on a given speaker.
ExactlySame thing. If its a perfect voltage source it will double the power. And amps are (if they use feedback) close until they start to current limit. Those numbers are at full power. If you try a 100watt amp at 1watt into 4ohms it will put 2watts into 2ohms.
That the ear uses higher ordered harmonics to sense sound pressure is well known (take a look at the Radiotron Designer's Guide 3rd edition from the 1930s) and easy to demonstrate with simple test equipment.This too is indeed your opinion and not universally considered a truth. Higher order harmonics would have to be really high (> 0.05%) and not be masked. To affect tonality the distortion would have to be substantial >1% or so.
Only tube amps or amplifiers 'designed by ear' would be able to reach such levels.
Can you point to any research showing what type of distortion and if low levels (say well below 0.1%) would affect tonality and make an amp sound bright or harsh ? Preferably with blind level matched tests as provided evidence ?
I probably could have worded that better- my point was simply that a design can be a proper voltage source and the fact that it may not be able to double power from its 8 Ohm full power level to 4 Ohms does not affect that. Heck, there are tube amps that act as voltage sources too, but instead of doubling their power from 8 Ohms going down, whatever their 4 Ohm power is they cut that in half as the load impedance is doubled. Expensive way to do it IMO.Its pretty much the same thing. If your voltage remains the same and your resistance is 1/2, your current doubles. High current is what is hard to achieve. You need bigger transformers, more power transistors..... Whats even worse is that BJT current output drops as their temperature increase. Your cost goes up, multiple transistors in parallel has it own design challenges too. You need output resistors.
This is why not that many amps out there (esp. budget ones) are able to drive lower impedance speakers.
To me this comment seems really suspect! Otherwise why is there an ongoing effort to keep it down? This comment must be out of context.Just recently there was an interview with @Sean Olive where he mentioned distortion is not a deciding factor in sound quality.
To be able to market such specs? Why are street cars able to drive faster than 200 km/h?Otherwise why is there an ongoing effort to keep it down?
Per John Atkinson "the [Krell] Evolution 600 was a powerhouse, clipping with continuous drive at 610W into 8 ohms (27.85dBW), 1190W into 4 ohms (27.75dBW), and 2.2kW into 2 ohms (27.4dBW). I don't hold my AC wall voltage constant for these tests; at 125.8V with the amplifier quiescent, it had dropped to 121.8V with the amplifier clipping into 4 ohms, 119V with it clipping into 2 ohms." Good enough for me.As has been widely discussed here, the "doubling" of power is typically a misdirection achieved by lowballing the 8 ohm figure in the first place, a practice that dates back to the 1970s. My old Bryston 3B (1987) allegedly doubled 100/200 but an 8 ohm load tested at nearly 140 watts.
You can certainly make that argument (as the departed Mr March did in extremis and contra Magico) but if the amp/speaker combination works for you (or me) it's moot.At some point, perhaps 2 ohms as you suggest, but maybe more, speakers that 'bring amps to their knees' are a design fail in and of themselves.
