For
@McFly
A little modelling of the
Mogami W3082 on the
ATC SCM40s vs. a
Mogami and a
Belden 12AWG wire and a lower capacitance
Belden 14AWG wire. I chose 12AWG based on the 4mm measure you gave, and 14 to compare similar resistance cable to the W3082. Just picked these wires because they looked like pretty standard wires and had easy to access spec sheets. Modeled using VirtuixCad based on
this page from Blue Jeans Cable. Used vendor spec sheets for R, L, and C values. And all the graphs are from the perspective of moving to W3082 from these other cables.
Tiny FR differences, less than .025(!) dB until the top two octaves, and even there the differences hit .06 dB at max. All the variation up to the top octaves can be explained by the thinner wire having higher resistance and therefore interacting more with the speaker impedance.
So what's causing the differences up top? I modeled the Belden 5100UE against versions of itself modified with specs for the W3082 to find out.
So the higher capacitance isn't causing the variations up top--that line is almost flat. It's actually the lower inductance. From what I understand increasing capacitance lowers inductance in cables and vice versa, so it may be in a sense related--someone more knowledgeable than me would have to fill in any answers on that front.
But why is this happening?
As far as I can tell, it's due to the speaker's capacitive phase angle in the treble interacting with the relatively lower inductance. As with the relationship between capacitance and inductance in cables, someone who knows more than me would have to fill in here too.
Anyway, this all looks pretty inaudible, but very small differences between some cables feeding that speaker do exist. Oh, and all the measures were normalized to 0 at 1000Hz. The overall level differences will be slightly larger than what can be seen here. The largest difference is between 7 and 12kHz, where the two Mogami cables differ in level by ~.09dB, with the next largest difference at ~.06dB at 100Hz. So if your old cable was indeed 12AWG, then your speakers are now probably ever so slightly quieter.
