That combination is indeed the pinnacle unless one needs serious amounts of shielding.Mogami Neglex 2534 Quad cables and Neutrik connectors
When I was still building my own cables, all I bought were Mogami Neglex 2534 and Neutrik jacks.
Nice looking cables but I hope you're listening to music instead looking at cables, this is more than enough: The postage cost more...After doing a lot of research and consideration, I finally got the upgraded RCA cables to connect my DX3 to my Sony integrated amp. They are made / assembled by Eno Audio here in Germany using Mogami Neglex 2534 Quad cables and Neutrik connectors. I paid EUR 61 to Amazon for the pair of 2 meter cables.
Very interesting to see the difference between the EUR 5 cables that I got for free when I bought the amp and the new cables; totally night and day. I'm very happy with the quality and value. These RCAs are the absolute upper limit of what I consider the best RCA cable available in terms of actual / real quality and price (as opposed to the snake oil brands and thousands of $$$$).
You could unscrew the RCANeutrik plugs and do some macro pictures with the soldering and the hot & shield wires. Also, if you have no more need for the older & cheap RCA cables, you could probably take of the outer jacket to see the wires inside, especially the shielding.Very interesting to see the difference between the EUR 5 cables that I got for free when I bought the amp and the new cables; totally night and day. I'm very happy with the quality and value.
Neither, since according to physics, electrons don't really exist.Which raises the question whether directional cables move electrons from right to left, or left to right?
Actually from some testing I did (hammering Ford 5x7s at full power for 280 hours or such) the break in appears to go on forever. But the response change, pretty small.speakers need a burn in time. He told me that this is untrue. Only the bass chassis will change a little bit during the first time because some parts get softer due to mechanical work. This lets the resonance frequency drop down a little bit,
That's a nice idea. Yeah, I'm familiar with that link too. It was part of my extensive research haha I've got no concerns about the cable being what it should be, as the brand and model are printed on the cable every few feet. My trust in the quality is also high, seeing as it's assembled here in Germany by a reputable companyYou could unscrew the RCANeutrik plugs and do some macro pictures with the soldering and the hot & shield wires. Also, if you have no more need for the older & cheap RCA cables, you could probably take of the outer jacket to see the wires inside, especially the shielding.
This way we could easily compare visually the difference between the two cables, although the cable can be seen here as well: http://www.mogamicable.com/category/bulk/microphone/quad/
Can anyone think of a good reason to take shielded star quad wire, and terminate RCA cables with all four conductors on the pin, with only the shield on the shield?
Sometimes it's all you have on hand. I've done it before.I can't think of a good reason to use star quad for an unbalanced connection in the first place.
It's 10 pounds of wires in a 5 pound connector shell.Can anyone think of a good reason to take shielded star quad wire, and terminate RCA cables with all four conductors on the pin, with only the shield on the shield?
But if you must:
connect one wire to the center pin.
connect the other three wires and the shield to the shell at both ends.
And if you want to make the same exact cable as the original Couple, all it’s made from is Klotz GY107 low capacitance cable stock and Neutrik Profi RCA plugs.Albeit overpriced, Rega Research used to make a very similar cable to that Eno cable above (called the “Couple”) from Klotz microphone cable and Neutrik connectors. No outrageous claims made by Rega. They were quite nice but their new Couple2 utilizes RCA plugs with significantly more “bling.” No thanks.
This audio cable business is getting out of hand...
No, wire it as in my post # 915.The reason I asked is because an “audiophile” cable merchant does that, not because I would.
I get having one type of cable that can be terminated for RCA or XLR. But if you’re going to use star quad for RCA at least treat it like parallel twisted pairs, right?
